Old 01-30-2018, 09:16 AM   #1
cebra
Wrangler Gas Tank with S10 Sender?
My gas tank is leaking so I ordered a 87-90 Wrangler Tank to put out back. I have the stock 350 motor now that I plan to run for a while and swap to a LS down the road. My plan is to run a fuel sender from a fuel injected motor with a short pickup hose so the stock 350 pump draws fuel from the tank. Then when I convert to LS, I can drop in a EP381 Pump to "push" fuel to the motor.
Does anyone see any issues with this setup on the stock motor? Also, does anyone know if a 92-93 S10 sender works as far as fuel level reading/sender ohm and the locking plate compatibility with the Wrangler tank? I saw another thread where a S10 sender was used but there was no conclusion to this. Thanks for any information you have.
cebra is offline   Reply With Quote
Old 01-30-2018, 09:30 AM   #2
clay68c10
clay68c10's Avatar
Re: Wrangler Gas Tank with S10 Sender?
The jeep sender may already have the right ohm range (0-90 as I recall). From the research I've done, the 91-95 YJ sender is the right ohm range. I'm planning on building a tank using the YJ EFI sender. The earlier version could be similar.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 01-30-2018, 09:46 AM   #3
cebra
That is good information. I think the issue using the Wrangler sending unit is that a EP381 for the LS will not drop in? If I could use the stock Wrangler sending unit that would definitely save a lot of mixing and matching for sure.
Old 01-30-2018, 10:21 AM   #4
clay68c10
clay68c10's Avatar
The hole in the tank may be big enough to sneak a pump in if it's mounted vertically on the sender. I'd sure give it a shot. Maybe find a pump dimension and mock something up with cardboard tube? I doubt that pump is more than 2" diameter.
13 Tahoe LTZ
Old 01-30-2018, 02:35 PM   #5
cebra
If nobody has done an S10 successfully, how about the full size Blazer sending unit? What level of modification is needed on this sending unit to drop in a EP381?
