Old 01-31-2018, 11:07 AM   #1
Sgtfluffy16
Headers
I have a 51 3100 that i am putting a 305 SBC, 700R4 trans, and 12 bolt out of a K10. I have 2 questions.
stock frame, stock front axle, stock steering column and steering gear. what header do i use? I heard a 265 front exit log header. I would like to do something with better flow. i also know that spacing the steering gear box out 2 inches is not uncommon either when doing this swap.
Now for the rear axle. With the purchase of these rear axle brackets (https://www.classicparts.com/1947-54...ctinfo/93-317/ How do i install the springs? They are factory height and still have the overloads on top. do i have to get another steel plate to mount on the (bottom) of the leaf springs to secure them to the rear axle? The factory has the rotation cam because its a torque tube currently and they springs mount under the axle tube.
Sgtfluffy16 is offline   Reply With Quote
Old 02-02-2018, 02:15 AM   #2
mr48chev
mr48chev's Avatar
Re: Headers
Offsetting the engine to the passenger side a tad helps with clearance and you don't have to move the steering box so far. You can't go much though as the clearance on the passenger side isn't that great.
My ongoing truck projects:
Old 02-02-2018, 08:16 AM   #3
hogfarm
Re: Headers
Good luck with the headers,I bought and returned 4 sets before I got it right
hogfarm is offline   Reply With Quote
Old 02-02-2018, 08:29 AM   #4
Sgtfluffy16
Re: Headers
......and? What did you end up with?
