Old 02-01-2018, 04:58 PM   #1
wpavlis
Torque Confusion
So I recently replaced the rear control arms, springs, and shocks on my 68 c10. I am confused about what torque settings to use. I have a FSM. In the instructions for control arm replacement it says the U-bolts should be torqued to 200 Ft-lbs. In the back of the manual the in the torque spec chart it shows 215 ft-lbs. I do have auxiliary springs, and under that section the instructions show yet a different value of 270 ft-lbs. I currently have them torqued to 200 as that is as far as my torque wrench goes. Do I need to find/borrow one that goes to 270? I have found other instances of this. I almost ruined one of my shocks as the instructions say to use 135 ft-lbs, but in the back it says 75 which I believe is accurate.
On the note of torques, I plan on pulling the aux springs off next to paint them. The manual shows a whopping 370 ft-lbs for the single mounting bolt. The factory used a castle nut with a cotter pin. If I even had a torque wrench capable of the 370 ft-lbs, my gut tells me the bolt would not hold that. What have others done? Thanks,
wpavlis is offline   Reply With Quote
Old 02-01-2018, 05:13 PM   #2
harpo231
harpo231's Avatar
Re: Torque Confusion
you will find aux springs take much more torque
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 02-01-2018, 05:16 PM   #3
harpo231
harpo231's Avatar
http://67-72chevytrucks.com/vboard/a...1&d=1517519785
Stan
67 swb BLU MULE
Old 02-01-2018, 05:22 PM   #4
wpavlis
Ha! That has even more different specs! I think the 270 must be correct for the u bolt. What about the auxiliary spring mounting bolt? Is 370 correct?
Old 02-01-2018, 05:29 PM   #5
harpo231
harpo231's Avatar
I have only the document I posted so I would say yes.. you can wait for the know it alls ,but may end up with more specs !!
Stan
67 swb BLU MULE
Old 02-01-2018, 08:21 PM   #6
RichardJ
After you decide on the specs, Make an extender for your torque wrench. I used a piece of 2" Channel iron and a Craftsmen breaker bar that already had the hole and flat sides. A U-joint strap holds it solidly in the Channel. The 1/2" square hole was drilled, then filed by hand.
A little math and you can use your torque wrench for just about anything. I have used this setup many times to do those front wheel drive and cartridge type axle nuts that sometimes call for 300 + ft-lbs
This was in Hot Rod Mag back in '84. I made this bar up and have used it many times over the years with my beam type torque wrench.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 02-01-2018, 11:13 PM   #7
mike16
bravo Richard. You beat me to it. the math bits a a little scarry but if in doubt there are SAE torque specs for hardware and its a range rather than a specific value.
mike16 is offline   Reply With Quote
