Old 02-05-2018, 03:18 PM   #1
jrusher
Ly6 an 4l80e going in my 65
Hey guys
I just picked up a 2008 ly6 and a 4l80e that was out of a Savana van and I’m going to swap it in my 65 c10 short bed . Have a few questions. My truck is pretty low 2.5” drop spindle an -2” spring in front and bags in rear .
I’d like to know what engine mounts/tranny cross member work the best for these trucks ? Also oil pan ? I’ve done some searching and looks like the gm performance muscle car pan should do the trick. Also headers haven’t found much info on what guys are using that’s not crazy money ?
Trying to keep a low budget on this build but I know how things add up in a hurry . I’m going to tear this thing down an hopefully only do a light hone an rings and a better cam and springs , car intake/injectors an seal it back up .
Thanks in advance for any help . These ls are all new to me lots to learn
jrusher is offline   Reply With Quote
Old 02-05-2018, 05:43 PM   #2
Clyde65
Clyde65's Avatar
Re: Ly6 an 4l80e going in my 65
Doug Thorley for headers
You use the stock perches and dirty Dingo sliders
Tranny you should be able to use the stock one but CPP sells an inexpensive one too.
Oil pan is a good choice.
Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 02-05-2018, 05:54 PM   #3
jrusher
Good luck!
Thanks Clyde !
Old 02-09-2018, 04:44 PM   #4
jrusher
Anybody run the sanderson headers on the 60-66 trucks ? Hows fitment with the newer series trannys? Price wise there alot cheaper than Dougs headers I might try a set
Old 02-09-2018, 07:45 PM   #5
Clyde65
Clyde65's Avatar
I have! CSLS1, nice sound and power
Clyde65
Rebuild of Clyde
support our troops!
Old 03-22-2018, 10:53 PM   #6
jrusher
Making some progress. Went through engine freshened up bottom end, heads and installed a Texas speed vvt cam kit. Almost ready to drop in waiting on tranny an time to clean up engine bay an weld up a fuel tank.
Old 03-23-2018, 10:42 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Also, your shop looks clean AF
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-20-2018, 01:50 PM   #8
jrusher
Getting my swap back on track . I got side tracked last 2 months or so changing out my floor an repairing all other rust in cab .
Old 06-20-2018, 01:54 PM   #9
jrusher
Had to swap roof skins an old antenna hole rotted through both skins
Old 06-20-2018, 01:56 PM   #10
jrusher
Few more
Old 06-20-2018, 01:59 PM   #11
jrusher
Couple more
Old 06-20-2018, 06:09 PM   #12
Daaaanz67
Nice build following this.
Daaaanz67 is offline   Reply With Quote
Old 09-07-2018, 07:45 AM   #13
jrusher
After 4.5 months of cab surgery and ls swap she’s finally back on the road. Thing rips good some fine tuning to go yet for cam but super happy with everything. Some better gearing and a posi next
Old 09-07-2018, 07:29 PM   #14
Clyde65
Clyde65's Avatar
Nice! That was a lot of work!
Clyde65
Rebuild of Clyde
support our troops!
Old 09-07-2018, 08:14 PM   #15
jrusher
Thx . Ya I didn’t do much else this summer except wrench lol
Old 09-09-2018, 10:48 PM   #16
57taskforce
All about them K’s
57taskforce's Avatar
Nice work!
Tyler
Old 04-05-2019, 04:30 PM   #17
Naught
Naught's Avatar
Did you have to do any mods to the trans tunnel for the 4l80 to fit? What motor mounts and trans cross member and mount did you use?
Naught is offline   Reply With Quote
Old 04-05-2019, 05:06 PM   #18
jrusher
4l80 fit fine, dirty dingo mounts, cpp cross member I had to shim it abit to get angle right. Any crossmember will work
Old 04-06-2019, 03:53 PM   #19
bigmoe
bigmoe's Avatar
Good job on the build. Looks great. Love the patina on that truck.
bigmoe is offline   Reply With Quote
Old 05-21-2019, 09:04 AM   #20
lownslw64
lownslw64's Avatar
Looks good! with the dirty dingo sliders and stock perches in the v8 location did you have any clearance issues on the the passenger side back of head/coil pack to cab. i am running similar setup and it is tight at that point.
1963 Chevy suburban, ls1/4l60e, 3 rows, barn doors
2007 chevy 2500 hd 4x4 duramax
lownslw64 is offline   Reply With Quote
Old 05-21-2019, 10:52 AM   #21
jrusher
I slid engine ahead just enough to clearance coil packs/bracket
Old 06-08-2019, 10:33 AM   #22
jrusher
Thought I’d update what I got for numbers after a tune and some dyno time . 380 hp at the wheels and 356 ft/torque. Decent numbers for just a cam, ls3 intake and 17/8” headers
Old 02-14-2022, 04:59 PM   #23
gtmywings
I did a LS1,4L60 swap out of a 2001 police Yukon in 2002 into my 65 C10, back then I had to fabricate mounts & wiring, no kits were available back then. The 4 biggest mistakes I made was using CPP parts when upgrading suspension & 5 lug 11" disk brake conversion, they wear out fast and usually don't fit right, the other mistakes was using VintageAir and Quik AC compressor brackets, so avoid CPP, VintageAir, Quik brackets, also avoid all "digital" dashes. Do not use anything wireless in the cab; wireless devices emit toxic EMF radiation and is very harmful in a metal cab. I'd like to get a short wheel base 64-66 C10 panel truck next, but I'm getting too old to work on cars now.
gtmywings is offline   Reply With Quote
