Old 02-10-2018, 05:09 PM   #1
oneshot
oneshot's Avatar
Lower radiator hose solution
On my 69' C10 I had trouble finding a lower radiator hose that would work with an after market aluminum radiator. I used this site to research it and found that a GATES 20843 may solve my problem. With a little work altering the lower nipple and shortening the hose at that end, I got it to work.
If you research on this site before asking, you will same a lot of time.
oneshot is offline   Reply With Quote
Old 02-10-2018, 06:11 PM   #2
toiletbowl54
Re: Lower radiator hose solution
is the hose rubbing on the frame or is it just the picture?
toiletbowl54 is offline   Reply With Quote
Old 02-10-2018, 07:41 PM   #3
Grumpy old man
Grumpy old man's Avatar
did you try twisting the hose so it lays on top of the frame rather than against it ?
https://www.autozone.com/cooling-hea...004_10495_6774
Old 02-10-2018, 08:23 PM   #4
oneshot
oneshot's Avatar
The hose is 1/2 " from the frame.
Old 02-10-2018, 11:23 PM   #5
Longhorn 69
Junior Member
Just wondering, could the hose have been turned end for end to fit?
Longhorn 69 is offline   Reply With Quote
Old 02-11-2018, 09:02 AM   #6
oneshot
oneshot's Avatar
I tried both ways and twisting it. There is only one way it will fit. Sorry about the last photo (out of focus and bad angle to show clearance).
Old 02-11-2018, 12:16 PM   #7
Wizo
Wizo's Avatar
yes but;when your engine is up and running at normal temperature that hose is going to expand (and contract when cooled back down.) will it still be a 1/2" from the frame??????? keep an eye on that. Just saying, because i had something similar to that happen on my Duramax. Got a hole rubbed right through the hose.
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 02-11-2018, 01:26 PM   #8
oneshot
oneshot's Avatar
The engine hasn't been (getting close) started and if that happens I will notch the frame or insulate the hose.
Old 02-11-2018, 02:54 PM   #9
huntznsam
It's a nice solution if you have the skills. Another option for those of us with zero aluminum welding skills is to spend a bit more time in the books.
https://www.gates.com/resources/reso...fication-guide
I spot a couple that might have been a better starting point.
FWIW, before I voided the warranty on a new radiator, I'd cut the hose and splice it rotating the ends, hoses being cheaper than radiators.
huntznsam is offline   Reply With Quote
Old 02-11-2018, 03:01 PM   #10
oneshot
oneshot's Avatar
I thought of that, but wanted a cleaner look.
Old 02-11-2018, 04:02 PM   #11
Keystone_Hate
I got this one from Rockauto and it fit perfect with no modification to anything. I have the same setup as you.
ACDELCO 24035L
Keystone_Hate is offline   Reply With Quote
Old 02-11-2018, 05:15 PM   #12
oneshot
oneshot's Avatar
I tried the ac delco 24035L and couldn't use it because I have a low mount alternator that was in the way. It's not shown in the last photo, I had to remove it to get the hose in place.
Old 02-11-2018, 07:18 PM   #13
Rufas
Rufas's Avatar
The HD radiator in my 70 GMC has the lower outlet the same as the OP's photo. I got one at NAPA. It fit just fine.
1970 GMC 2500
700R Trans, RideTech 4 link rear suspension, air bagged on all four corners, factory upper/lower A-Arms, 2 inch drop spindles.
350 SBC 300hp
Weiand Supercharger
FiTech 30004 EFI
Rufas is offline   Reply With Quote
Old 02-11-2018, 08:01 PM   #14
Keystone_Hate
Ah gotcha.
Old 02-12-2018, 03:52 PM   #15
oneshot
oneshot's Avatar
Here is a photo with the alternator installed
