02-12-2018, 10:04 PM | #1 |
8 Lug 20 Inch Steelies
Well, I've been looking for some these for a while. Detroit Steel just started making them. I ordered some 20X9s and will post up some pictures here in 3 to 3.5 weeks when they come in.
They also come in 22 inch, but you can't get the beauty rings with the 22s. |
02-13-2018, 06:04 AM | #2 |
Re: 8 Lug 20 Inch Steelies
Looking forward to the pics. Will they take the 3/4 ton caps with clips.
John 69 c20, 396, th400, dana60, ps, ac |
02-13-2018, 09:44 PM | #3 |
They will drill, tap and mount clips so you can use the stock cap. I'm going with 2003ish cap shown in the pic. Here are some pics from Detroit Steel and Penn C10.
02-14-2018, 05:47 AM | #4 |
Thanks for the reply. Those 2003 caps look great on them.
02-14-2018, 01:42 PM | #5 |
What kind of back spacing did you get? I'm debating whether I should get those or waiting for artillery style. For those '03 style caps you just need the threaded lug nuts right?
02-15-2018, 01:41 AM | #6 |
THANK YOU for posting this!!!! That information just made my day!!! I can't wait to see pictures of them on your truck!
Joe |
02-15-2018, 08:20 PM | #7 |
02-15-2018, 08:59 PM | #8 |
Good luck. Just ordered mine today. Went with 20x9 5.5 b.s. in front 20x9 4.5 b.s. in back. Let's see how it goes.
02-15-2018, 09:17 PM | #9 |
02-16-2018, 10:09 AM | #10 |
In for pics!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
03-08-2018, 07:54 PM | #11 |
Well,
I got 3 of 5 packages today. I just couldn't help myself though. Last edited by thehata1; 03-08-2018 at 09:12 PM. |
03-08-2018, 07:57 PM | #12 |
Well, that didn’t work well...
I’ll fix the photos when I’m done. Last edited by thehata1; 03-08-2018 at 09:16 PM. |
03-08-2018, 08:20 PM | #13 |
I may need to reconsider my 8 lug wheel options, ...I like the look of these
03-08-2018, 08:27 PM | #14 |
Nice!! Just got mine powder coated. Should have them on tomorrow. Trim rings should arrive tomorrow also.
03-10-2018, 07:20 AM | #15 |
Well that just looks fabulous! What tires are you going to get?
03-08-2018, 09:37 PM | #16 |
Jose,
How did that cap clear the rear axle? I'm having hell with mine. |
03-08-2018, 09:49 PM | #17 |
I think yours are a bit different. Mine fit good. Might have to trim the rear ones on the little stems inside. I was able to get the plastic nut to catch on the rear ones but didn't turn a whole lot. They're off 88-99 truck I think.
03-08-2018, 10:01 PM | #18 |
I may end up swapping to your style then. I had to get some dually caps for the rear. But, plastic caps don't hit the lug threads...
03-08-2018, 10:21 PM | #19 |
Can you trim the base to make them shorter? I thought I read some posts of people doing that.
03-08-2018, 11:31 PM | #20 |
Wow they look amazing.
I have to go and convince my wife that they are a necessary safety item for the truck.
03-09-2018, 10:48 PM | #21 |
03-09-2018, 11:22 PM | #22 |
hata/Jose,
...just curious for your respective trucks, what sort of drop are you running (front and rear)? I'm considering these wheels and want to be sure things clear. As well, please post pics when tires are mounted Thanks, Kevin |
03-10-2018, 12:29 AM | #23 |
I did 2.5 inch drop spindle in front and 1 inch lowering spring. In the back I have a 4 inch drop spring and 1.5 inch lowering block.
03-16-2018, 04:55 PM | #24 | |
To my knowledge, the front end is not lowered. I'm lowering the rear end this weekend. I'll post some before and afters. |
03-10-2018, 07:11 PM | #25 |
Here it is all shoed up. I named him Pappaw. Still waiting on the beauty rings. Hopefully they’ll get here Monday. I'm going to lower the back about an inch. I plan on towing with this truck.
Wheels are 20X9 all the way around. 5 inch backspacing in front and 4 inch backspacing in rear. Tires are Continental 275/45R20. I chose Continental because of availability in the size I wanted and they’re asymmetrical, so I can rotate sides. And, yes, the bed is not set straight. I’ll fix that soon. Last edited by thehata1; 03-10-2018 at 07:18 PM. Reason: iPhones suck... |
