Old 02-14-2018, 12:50 PM   #1
demian5
demian5's Avatar
Grounds - Useful Information
Please add to this thread for ground connections but in my experience with GM vehicle, the grounds should be:
  • Cable between battery and engine (alternator bracket, water pump bolt, or bolt on front of block by fuel pump)
  • Cable between battery and vehicle body (inner fender usually)
  • Cable between engine and vehicle body (firewall and valve cover bolt usually)
  • Cable between engine and chassis (valve cover bolt and frame)
  • Cable between chassis and vehicle body (under cab)
I had to add one between my cluster and firewall because of the usual cluster lighting issues many have.
A simple check to see if you have a ground problem (slow crank when hot for example):
Take a set of battery cables (which you were going to ask for a jump start for the slow crank issue anyways) and do this:
  • Hook one end to the engine block, the other end to the frame.
  • For the other jumper cable, connect one end to the body and the other to the frame or engine block.
  • If it cranks OK, verify you have good, clean, and sufficient grounds.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 02-14-2018, 01:26 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Grounds - Useful Information
Here is an older thread, It spans quite a few years (2010-2018) but it covers just about everything.
https://67-72chevytrucks.com/vboard/...d.php?t=422234
Really shouldn't have to add a ground to the cluster if the original one is there and it is making good contact. Most of the time a bad ground to the cluster is because the cab isn't grounded correctly.
LockDoc
Leon
Old 02-15-2018, 02:57 PM   #3
randy500
LockDoc
AGREED on the cluster ground, dumbest thing I have ever heard of....the cluster ground is via a clip to the dash, if there is a ground problem its in the ground straps at the engine, the inner front fender or the cab, FIX the actual Problem...............
randy500 is offline   Reply With Quote
Old 02-14-2018, 09:18 PM   #4
custom10nut
custom10nut's Avatar
Subbed.
custom10nut is offline   Reply With Quote
Old 02-15-2018, 12:32 AM   #5
Steeveedee
Who Changed This?
Steeveedee's Avatar
We're working on some really old iron. Any connection made at the factory is suspect, even if someone did a frame-off, because corrosion waits for no one. (Rust never sleeps" :P ) My temp gauge went south, probably from corrosion. I'm thinking about replacing the whole instrument panel with custom gauges, to eliminate that printed circuit board which is certain to be corroded, based on what else I've seen in the cab. This on a truck that lives in the "irrigated desert" in southern California.
~Steven
Simi Valley, CA
Old 02-15-2018, 08:16 AM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Grounds - Useful Information
I have added extra grounds to all my old vehicles. Just good preventive maintenance to do it as said with older vehicles.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 02-15-2018, 12:54 PM   #7
OregonNed
OregonNed's Avatar
I remade all my grounds when the box was off a while back. Probably overkill but I have access to great bonding materials where I work.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 02-16-2018, 11:13 AM   #8
Shaky
Six in a row makes it go...
Shaky's Avatar
Any idea what that stuff is called? I'd like to track some down to have on-hand.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 02-16-2018, 03:56 PM   #9
OregonNed
OregonNed's Avatar
I took a quick look around and it doesn't appear to be manufactured any more. I could probably get some to you if you wanted to pay the shipping cost.
Old 02-18-2018, 06:49 AM   #10
Shaky
Shaky's Avatar
Wow - that's a generous offer. It looks like Burbor tracked it down - I'll probably order that since I'll probably be going through a significant amount between my projects and some other people's...
Thanks!
Old 02-16-2018, 06:05 PM   #11
Burbor
Looks like that braid is made by 3M: http://m.3m.com/wps/portal/3M/en_US/...294469250&rt=d
Burbor is offline   Reply With Quote
Old 02-18-2018, 07:42 AM   #12
Shaky
Shaky's Avatar
It looks like McMaster has it here:
https://www.mcmaster.com/#bonding-an...pment/=1bmek1r
Old 02-18-2018, 10:16 AM   #13
Richard2112
Richard2112's Avatar
I recently added a ground strap from my cluster to the firewall and inside the engine compartment, from the firewall to the block. Going to add yet another but haven't decided exactly what location yet. As had been said, grounds can't be trusted on vehicles this old and they are generally neglected. Sufficient grounding improves a great many things and increases the life of components.
Richard2112 is offline   Reply With Quote
Old 02-18-2018, 12:13 PM   #14
mike16
I have a ground going from the underside corner of the rear bumper to the sheet metal across from it.
mike16 is offline   Reply With Quote
Old 02-18-2018, 12:37 PM   #15
OregonNed
OregonNed's Avatar
Glad you guys found something still being made out there! I still use the smaller brade from the back of both heads to the firewall. The big braid is great for chassis grounds.
