Old 02-15-2018, 11:53 PM   #1
upon1
upon1's Avatar
Overflow tank
I’m trying to tie up the loose ends of my ls swap and wasn’t sure if a rad overflow was really needed? I’m using a champion rad and there isn’t a ton of space under the hood of a ‘54. Sorry about the sideways pic.
"Lifes to short to drive an ugly truck."
Project 55 To Life
http://67-72chevytrucks.com/vboard/s...d.php?t=432994
upon1 is offline   Reply With Quote
Old 02-16-2018, 12:19 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Overflow tank
Overflow tanks are not really needed, but may be required if you want to take it to the track or autocross it or something. Otherwise just don't fill the radiator all the way up so the coolant has room to expand just like in the old days. If you do overfill it, it will just puke out what it cant hold, then should be fine.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 02-16-2018, 08:32 AM   #3
homemade87
Re: Overflow tank
I used one of these . It is an expansion tank that allows the fluid to travel back and forth to keep the radiator full . I prefer to do this for max cooling . I mounted it in front of the core support behind the grill .
https://www.oreillyauto.com/detail/d.../jeep/wrangler
There is so many sizes and shapes I am sure you could find something to work . Also you can spend as much or as little as you want . They will do the same thing .
homemade87 is offline   Reply With Quote
