02-16-2018, 11:02 PM | #1 |
Removing Choke And Throttle knobs 67 cluster
I need to remove the cluster out of my 67. How do I remove the knobs off of the choke and throttle. How do I do that?
1977 Chevrolet K10 SWB Project 350/4spd/np205 1977 Chevrolet K20 LWB 350/350/203 1991 4Runner 22RE 5 SPD Yanmar Tractor 3 Cyl Diesel |
02-17-2018, 12:00 AM | #2 |
Roadtrip!
Re: Removing Choke And Throttle knobs 67 cluster
For the choke, pull it out a little bit and hold onto the metal rod with a pliers and unscrew it. For a manual throttle, there will be a little set screw going in sideways like a wiper knob.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
02-17-2018, 12:24 AM | #3 |
Thank you!
03-12-2022, 06:25 PM | #4 | |
I also thought about disconnecting the choke cable from the carb and pulling it through, but the cable has a little bend on the crab end. I'm troubleshooting my fuel gauge and just want a little peek in. Not wanting to buy a choke cable.
Kitsbeach (Ken) 1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills" |
03-12-2022, 06:39 PM | #5 |
If you are just wanting to pull the instrument cluster out a little bit,
You can remove the screw in the cable clamp on the carb. That is an aftermarket choke cable. Hope this helps.
03-12-2022, 07:05 PM | #6 | |
03-12-2022, 07:12 PM | #7 |
I managed to get my hands in behind and there was a nut on back that I could loosen and get some room to see in.
It is an aftermarket cable. Looks like i could disconnect from the carb end and thread the whole cable assembly out, but I just need a peek in to see if my fuel gauge wires are all intact. Sorry for the sideways pictures.!!
04-09-2018, 02:19 PM | #8 |
Thank you. Big help.
Why would they want to make them all the same.....
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
