02-17-2018, 02:08 AM | #1 |
What is this loose cable inside the engine bay?
I just noticed this loose cable next the the carb, under the air filter.
Any idea what it is? Looks like a bicycle brake cable.
1965 Chevy C-10 350 V8 2003 GMC Sierra Crew Cab 6.0L 4x4 |
02-17-2018, 02:15 AM | #2 |
Re: What is this loose cable inside the engine bay?
It's a cable to the valve body in your transmission. It's fairly important in a TH350, and VERY important in a 700R4. It pins onto the throttle at the bottom. See that slot? It is adjusted such that it is usually pulled fully at wide open throttle (it will not move at all for the first half of your throttle as there will be no contact yet).
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
02-17-2018, 02:46 AM | #3 | |
I wonder how long it has been disconnected. Driveability hasn't changed.
02-17-2018, 12:09 PM | #4 |
One foot in front of the other
What trans do you have? Looks like it was here at one time?
02-17-2018, 08:01 PM | #5 |
Ok thanks for all the infos fellas.
I have a th350, so it looks like it is not mandatory to have this cable hookedup eh?
02-17-2018, 07:53 AM | #6 |
I think it's called the kick down cable. Makes it downshift when you put the hammer down.
02-17-2018, 08:51 PM | #7 |
Moderator
Only if you want your trans to work correctly. It's the kick down cable.
02-17-2018, 08:59 PM | #8 |
I read on jalopyjournal that if you don't drive WOT, then the cable never activates anything. Since I don't drive WOT with this truck, I guess I am ok leaving it unhooked.
02-17-2018, 09:58 PM | #9 |
Moderator
Your logic makes ZERO sense. No WOT ever? We're not talking about drag racing or going to Bonneville. Think about passing someone. Think about accelerating at full throttle for safety reasons, like getting out of someone's way. Fix your truck.
02-17-2018, 11:37 PM | #10 |
No I can't remember a time ever driving WOT in this truck. I guess I am a slow poke. I just cruise slow.
02-17-2018, 10:29 PM | #11 |
I'd hook it up. You can always disconnect it.
Use a nylon lock nut if you do. It wont bind and won't vibrate off again. Looks like the screw and washers are still there. |
