02-17-2018, 12:29 PM | #1 |
Differences in a 68 and 72 cab
I need a cab for my 68 and I found a 72 cab for sale on the classifieds here. Before I commit to it I just wanted to see if there were any changes made that would make swapping cabs a real headache.
1968 C10 |
02-17-2018, 12:46 PM | #2 |
Re: Differences in a 68 and 72 cab
I believe just where the rearview mirror goes will be the only difference.
02-17-2018, 01:04 PM | #3 |
Yes rearview mirror, but also ebrake mounting and driver-side cab vent at rear door opening, which affected placement of the vin plate. Think the gas pedal setup might be a little different too.
02-17-2018, 01:21 PM | #4 |
Thanks guys, that doesn't sound too bad.
1968 C10 |
02-17-2018, 01:25 PM | #5 |
Also cab fuse block mounting and wiper switch is above the light switch on a 68 and on the right side top on dash on a 69-72
02-17-2018, 01:38 PM | #6 |
The fuse block is just moved over a bit yeah? Same size though?
1968 C10 |
02-17-2018, 01:47 PM | #7 |
You also have cable instead of rod for accelerator.
02-17-2018, 04:30 PM | #8 |
I'm doing a 68 to 71 cab swap myself. Here's what I've found so far.
Mirror mounting (72 on glass), e-brake, fuse box, gas pedal, VIN plate, cab pillar vents, filler neck grommet, and the label for the ignition switch. I think that's all.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
02-17-2018, 05:43 PM | #9 | |
Are you converting your e-brake to the foot pedal type or finding a way to make the hand lever work? And is the fuse box just in a different spot or is it more complicated than that?
1968 C10 |
02-17-2018, 06:12 PM | #10 |
I'm going to use my 68 dash in the 71 cab. I will use the 68 style e-brake. The cable goes out under the column, the flat spot is there on the 71 cab, it's just not drilled.
It looks like the harness is the same where it goes thru the firewall. I think the fuse box just sits in a slightly different spot, rotated 90deg. I haven't looked that close yet.
02-17-2018, 06:20 PM | #11 |
Thw window crank and door release pivots are longer and the door panels are plastic not metal.
02-19-2018, 10:02 PM | #12 |
Somebody correct me if I am wrong. If you have stainless trim around the windshield and back glass, it is different . Either its not as deep or you have to buy different rubber. They are not an exact fit, I don't think.
:My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=807535 1972 K10 swb/1968 Camaro 350/4spd 1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5 |
02-19-2018, 10:17 PM | #13 |
Make sure get title with cab !
Stan 67 swb BLU MULE posted via flip-fone |
