02-23-2018, 03:19 AM | #1 |
Post your "Special Paint" RPO truck (aka: the Definitive Special Paint thread)
The title says it all. There are a bunch of special paint threads posted throughout the forum and new RPO codes seem to be popping up every now and then, so thought it might be a good idea to start a one-stop-shopping showcase of original paint trucks with "Special Paint" RPOs on the SPIDs. So, the idea is post a pic of the truck and the SPID, and we'll start a library of sorts of Special Paint codes. I've yet to figure out how to decode the color by just looking at the RPO - have only been able to know what one should be by comparison to an original one. So, if that's the best we can do, it would still be helpful.
Lots of interesting tidbits on Special Paint floating around out there. "Normally" Special Paint terminology seemed to be used when a factory color that wasn't necessarily available on a light duty truck was used - or - when a non-standard two combination was used (not a "Custom Two Tone" though, as RPO codes existed for those HERE). For instance, I had a 76 K20 that was just good ol Orange. But in 76, RPO 88 orange was a medium duty or above color - so it took a Special Paint RPO to get it on my K20. That's just one example. I'll go first, please share yours (or one that you have the info on, you don't have to own it of course) 71 Cheyenne Super Special Paint RPO = 4001BB 69 C20 CST Special Paint RPO = ZP3 (This one really confuses me, I think ZP3 evolved into a two tone combo code in the square body years, this is the only time I've seen it in this era. All other Special Paint RPOs I've seen in the 67-72 range looked like some variation of the one listed above for the Cheyenne Super). |
02-23-2018, 03:24 AM | #2 |
Re: Post your "Special Paint" RPO truck (aka: the Definitive Special Paint thread)
70 C20 CST Longhorn
Special Paint RPO = 1001M1 (this is the Canadian-only Purple, I believe? - but I think I've also seen that same code for a Canadian only green...) Ok, show us what you've got. Kevin, Robert! Post yours up too even though they are floating around in other threads! Thanks guys. Last edited by jocko; 02-23-2018 at 03:35 AM. |
02-24-2018, 07:27 PM | #3 | |
70+ ( Old Skool Club )
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
02-26-2018, 10:10 PM | #4 | |
02-26-2018, 10:16 PM | #5 |
Here's one I saw on here not too long ago, but I don't remember how old the post was when I found it. At first glance, appears to just be ochre, but on closer look, appears darker, more brown in it than ochre. Not sure what it is... Nice K20 though! Special Paint Code: 4001BB
It's also possible (likely) this is a repaint, it's not a "known" original paint truck, but it doesn't look like it was repainted in a stock color either. Is this a members? |
02-27-2018, 12:53 AM | #6 |
Who Changed This?
That definitely isn't ochre. I wonder what color it really is. Nice, in any event.
02-27-2018, 04:16 PM | #7 | |
02-23-2018, 09:54 AM | #8 |
Still plays with trucks
Special paint code ZP3 for a fleet color specific to Pacific Telephone & Telegraph.
Outside was repainted but interior was not. Toggle switch and lamp were for roof top mounted service lamp. 1969 C10 stepside short bed. 6-cyl 3 on the tree Chevy optioned with leaf spring rear suspension and heavy duty springs.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
02-23-2018, 02:53 PM | #9 | |
Special paint process, per author/illustrator/historian Eric White.
This was written specifically for Pontiac Motor Division, but you get the idea: Quote:
For Pontiacs the cowl trim tag will indicate the vehicle received a special paint color but will not designate what that color was; It is not documented anywere including through Pontiac Historic Services. The only real way to determine is to pull off rubber trim or otherwise disassemble the car and look for remaining splashes of the original color. These days you have to have a minimum of 10 or so, and it is not available to the general public but more specific to fleets and special orders (police, Mary Kay, Grand Trunk RR, RCMP, etc).
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-23-2018, 02:54 PM | #10 |
Additionally, when we painted special colors or fleet orders in the assembly plant we did not use the regular paint supply system.
In Flint they had a separate and distinct setup with smaller paint "pots" which could be loaded with the specific color, used, and then purged with less waste than the high volume production system. Some of the other locations did not have this and would run special colors through their paint repair line in the paint shop. K
02-23-2018, 04:43 PM | #11 |
Moderator
Special paint. Loaded with some nice options too. All it needs is a K chassis under it....
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
02-23-2018, 05:54 PM | #12 |
This is mine, 71 C-20 ordered originally by Burlington Northern Rail Road, delivered new in Seattle.307 4spd, power brakes, heavy duty rear springs , pozi, white painted bumper. 52000 original miles. Its beat up pretty good around the bed area, but amazingly dependable.
71 C-20 07 Magnum RT AWD |
02-23-2018, 07:10 PM | #13 |
I remember when the Burlington Northern took over the railroads through north Idaho. That green was a pretty wild color at the time and it seemed like for a while everybody was talking about it especially after the black engines they were running before. There was a guy who worked for them down the road from us and often had a 1 1/2 ton service truck parked at his house that was the new green with the angled white stripes on the back of the service boxes. I don't remember what kind of truck it was but boy was it bright. When they were freshly painted they really popped
http://www.carrtracks.com/idnp1456bn8104.htm Now back to your regularly scheduled thread.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-23-2018, 07:29 PM | #14 |
Florida Edition
Working on finishing this one. Long story but I found the original salesman that ordered this for his friend 'Charlie'. The special paint was Black Cherry, a Chevelle color for 1970.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by RenoKeene; 02-24-2018 at 12:26 PM. |
02-23-2018, 08:52 PM | #15 |
558 dark blue/med. blue.Unfortunately it has been repainted to light blue/ white. Will start a tear down as soon as it warms up a little. Plans are to paint it back to original color. It's not a special color but fairly rare.
'64 C10 LWB, 283, 5speed '68 C20 LWB, 327, 4speed '69 C20 Custom Camper Longhorn, 350, 4speed '72 C20 Cheyenne Super, 396, TH400 '66 C60, 292, 4speed |
02-23-2018, 09:39 PM | #16 |
Me like
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
02-28-2018, 10:18 AM | #17 |
Interesting. My 1970 has the identical special paint code, and the truck is white. I mean white all over. If there is a non-white color anywhere I cannot find it. Lots of things can happen in 48 years I guess.
02-23-2018, 09:36 PM | #18 |
RenoKeene, THAT is cool. Black cherry is a great color.
Just to be clear, there is a difference between a "Special Paint" RPO and a "Custom Two Tone" RPO. My 557 truck, for example, is a Custom Two Tone - you can see these in the LINK posted in the very 1st post in this thread. Special Paint are ones that actually state Special Paint on the SPID, i.e. no actual colors listed - and the need for a thread to group all the examples so we can figure out what unique colors and combos are out there. ElKotze, for the record, I think your 558 is about my absolute favorite paint that was available on these trucks. I like my 557, but 558 to me is about the best looking combo out there. |
02-24-2018, 01:14 PM | #19 |
Thanks for all that great info Keith! Very helpful.
02-24-2018, 03:28 PM | #20 |
I've already posted this, but to bring it into this thread.
1968 with "SPECIAL PAINT 91001LG" on the SPID. link to original post/thread for reference (http://67-72chevytrucks.com/vboard/s...83#post8195883) |
02-24-2018, 03:32 PM | #21 |
Thanks very much Kevin - was hoping you'd bring your recent post over here. Yours was the most recent in a bunch of separate threads about Special Paint RPOs, so thought it might be nice to get some one stop shopping. Really like your truck!
11-30-2020, 02:48 PM | #22 |
Carpe manana
Member argonaut has this beautiful highlander Blazer (please sell it to me ). http://67-72chevytrucks.com/vboard/s...d.php?t=741141
Blue original paint I guess? Any way to decode what paint was used?
11-30-2020, 06:22 PM | #23 | |
Who Changed This?
http://chevellestuff.net/1970/paint.htm
11-30-2020, 07:27 PM | #24 |
My 72 . Husky edition had the truck interior gunned and it came out as code 53 which in 1972 was Placer Gold .
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 11-30-2020 at 07:42 PM. |
11-30-2020, 10:07 PM | #25 | |
Carpe manana
Tags |
special paint |
