![]() Join Date: Jun 2017
Frame coatings
What do you guys coat your frames with after blasting them? I've thought about powder coating, but not sure if that is the right idea. Also has anyone ever coated the inside of their floors or the underside of their cabs with Bedliner?
Re: Frame coatings
3 coats of SPI epoxy
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
![]() Join Date: Feb 2016
Re: Frame coatings
Do a search for " powder coating frame". You will find several threads on it. Here is one to start. The same thing for the undercoatings.
http://67-72chevytrucks.com/vboard/s...d.php?t=648348
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
![]() Join Date: Nov 2014
Re: Frame coatings
I used Chassis Saver.
![]() Join Date: Dec 1999
Re: Frame coatings
#6 | |
Re: Frame coatings
I've painted with POR 15. KBS Coatings makes a good alternative. Cheap, strong, flexible. Can be touched up easily. Not quite as tough as powder coat, but doesn't brittle up over time. And, I've simply wet painted in both chassis black and body color. I use single stage urethane. Easy to touch up, but tough to keep clean. Can be polished and painted on again. Not as tough as the other two, but looks really classy. Take your pick... Least expensive was likely the POR 15. A quart and a bunch of small brushes does the entire frame. Self levels, was very easy to do. I still use this to touch up bolts and various frame bits. Good Luck! Remember, you asked for opinions... This is just my opinion of my experiences... |
#7 | |
Re: Frame coatings
Re: Frame coatings
I would probably just use paint myself. I've painted things with Rust-oleum and had them sit outdoor for years without rusting.
I have a question for those that used POR 15. If you lift the truck does it get leave marks where it contacts the frame? |
#9 | |
Re: Frame coatings
DY |
Re: Frame coatings
Robert:
I've sprayed POR 15 and used a brush. Really, brushing is about as easy as spraying and looks as good. The downside is it takes time. The upside is, you use a LOT less product. You have to remember that POR 15 and/or the KBS coating product are not like typical paints. They are heavy, and you thin them with Zylene or the special thinner provided by the company (Zylene based I'm sure). Only thin about 10% tops for either one. They set up by absorbing moisture. So, any moisture in the air line will start the process in the gun, likely ruining it. I just buy cheap guns at Harbor Freight and if I have a problem, throw it away. You can do either way. Don't discount the 'ole paint brush (a cheap one) with POR 15, as it self levels and will lay down and look great! And, it's easy to do one side of the frame, turn it over after it dries, and do the other side. Plus, if you miss a spot, simply brush it on and it will self level and hide the spot. Just remember to only use these products on area that will not see sunlight, as they will discolor over time in direct sun only. If you're using them on anything that sees sun, you have to topcoat. KBS also makes a DTM product for top coating. Others will have more experience than I do with this, but I'm doing the subframe on my next project (1970 Camaro) with this rather than powder coating. I like this process. Thanks, DY |
Re: Frame coatings
A POR 15 frame, painted with a cheap brush...
Re: Frame coatings
And, the current project. Wet painted with single stage urethane. I tried to load both pix in a single reply, but got an error message about "missing a security token"...
this was the only way I could get them to load. Sorry for the double reply. Just follow directions however you choose to do it. It will work, and look great! DY |
Re: Frame coatings
My latest project, Sprayed 2 coats Eastwood black epoxy . 2 coats Hamerite black.
Re: Frame coatings
#15 |
Re: Frame coatings
Epoxy acts as the primer. Everything I can find points to epoxy being one of the best products to adhere to and seal bare metal.
Alex V. ------ 1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs. 1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue. |
#16 |
Re: Frame coatings
On the one I did last year I layed down two coats of Transtar 2K epoxy and a couple more of Rust-oleum satin black tractor enamel. Got a good result that I think will last quite a while.
#17 |
Re: Frame coatings
I am a big fan of using industrial enamels or single stage urethanes on the frame. I guess because I am not going for high end show quality and I don't want to spend a lot of time making it "shine" my vehicles get driven when the weather is decent and I am not going to crawl around under them cleaning up all the water spots.
A few coats of industrial enamel is pretty cheap on the frame and I really like using rustoleum on the underside of the floor pans, wheel wells, and wherever. I usually spray the first coat, but then follow up with a few coats of brushing to get some thickness to it and tie in the tight spots. My theory on anything under the truck is "thick and heavy and satin". If you have every seen where the factory got a big run of paint, say on an inner fender, the area where the paint was one layer thick may be all surface rusted, but where the run is, the steel will still be protected and take some extra effort to strip off. Hence the "heavy" part of my theory. I like using satin paint just because it does not draw attention to any flaws and can be touched up with a brush. I can't tell you how many times I had to touch up the under side of a recent project due to scratches that happened during the assembly process. If the vehicle is a trailer queen, seriously consider powder coat or another high end system, if not, two or three coats applied to properly prepped steel will be far better than anything I have seen from the factory. If the truck will be concourse correct, then barely give it any paint and make sure you overspray in all the right places. I sand blasted my frame and then used several cans of brake clean to wash it down the day that the self etching primer and paint was applied. Obviously, sand dust and residual oils can thwart your efforts. Prep is key regardless of the paint used!
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
#18 |
Re: Frame coatings
I sandblasted my frame and coated with POR15 brushed on. Lays down great and levels out awesome. I did not topcoat, hoping the finish doesn't discolor. Time will tell how durable it is.
I replaced my whole cab floor, rockers, pillars, cab corners and coated the top and bottom of the floor with raptor liner. It looks awesome, feels like line X. $120 buys plenty of material and the spray gun, super easy to apply |
#19 |
![]() Join Date: Oct 2012
Re: Frame coatings
I planned on doing powder coat, but changed directions and will do mobile dustless blasting and SPI epoxy. I've used it enough on other projects and my cab most recently, and it is some really good stuff. I do believe Barry recommends 3 coats on frames.
https://www.southernpolyurethanes.com/
1969 Chevy C10 SWB Fleet - Build thread > http://67-72chevytrucks.com/vboard/s...d.php?t=593554 2008 GMC Sierra Denali - 6.2L AWD - my daily 2011 Ford Flex Limited - Ecoboost AWD - wife's daily 1987 Buick Regal Turbo T - 63K miles - Strip/Street car 1965 Ford Mustang Coupe - 289, c4, 53K miles |
#20 |
Re: Frame coatings
Stan 67 swb BLU MULE posted via flip-fone |
#21 |
Re: Frame coatings
The chassis coating products such as POR-15 are made to level out when brushes to look smooth as sprayed on. The reason many prefer brushing over spraying is use of materials. When spraying you will be blowing a lot of material past the frame wasted into the air. Brushing puts virtually all material on the project and one coat equals multiple sprayed coats.
#22 |
Re: Frame coatings
Another good reason for brushing on POR 15 is the fumes. The warnings on that stuff clearly states that you will DIE if you merely read the label. Well, not really, but you won't catch me spraying that stuff. I brushed on about a quart in an open shop and the fumes were not bad, but spray painting is a whole lot different. You would also want to prep the night before and start applying the Por-15 first thing in the morning so that it can tack up and take a second coat. If it sits too long, you will have to sand it to take the next coat.
#23 |
Re: Frame coatings
Epoxy is DTM, direct to metal...I did use metal prep, Phosphoric acid, paint over it after it drys. POR 15, and several other company's sell it. Post some photo's when you get it going.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 Last edited by notsolo; 02-26-2018 at 09:03 PM. Reason: Add photo |
#24 |
Re: Frame coatings
#25 |
Re: Frame coatings
This gives me good info to start with. Thanks for all your info on this question.
