03-07-2018, 03:25 PM | #1 |
Flex plate question
Trying to figure out why this was done to the flex plate.Came out of a 72 half ton with a 350/th350.
03-07-2018, 03:39 PM | #2 |
Re: Flex plate question
balance
Stan 67 swb BLU MULE posted via flip-fone |
03-08-2018, 03:11 PM | #3 |
Thanks harpo321.What I meant to say was how this was done to the flex plate.
03-08-2018, 03:41 PM | #4 |
The flexplate is spun on a balancer. There is a drill press set up on the balancer, the operator drills the flywheel/flexplate where the machine shows it is heavy.
03-08-2018, 03:54 PM | #5 |
Thanks for the info B.W. Kind of an odd shaped hole that's why I asked .
03-08-2018, 04:09 PM | #6 |
That kind of hole is caused by a dull or incorrectly sharpened drill
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
03-08-2018, 04:10 PM | #7 |
it's odd shaped because the drill bit walked around as it was drilled into the metal....
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
03-08-2018, 05:54 PM | #8 |
its easier to balance the outside of the flexplate than at the centre line of the crank, less material needs to be removed. they normally balance with a hand drill on the balance machine
GMC K1500 1971 350 cu in th350 4wd Bondo Bob c 10 1971 stepside th 350 c10 1970 350 cu in manual air con stepside. |
03-08-2018, 10:37 PM | #9 |
Who Changed This?
Exactly! That is an artifact of a hand-held drill that has no pilot hole. Even if a pilot hole was drilled, the bit will wander if used in a hand held drill. The amount of metal removed here is in the single-digit grams.
03-08-2018, 10:44 PM | #10 |
Most drill bits will leave a triangular hole in thin metal. If you want them round, then that's where a reamer comes in for the finish
