03-09-2018, 12:15 PM | #1 |
How do you confirm matching numbers on a 72 k5?
Thanks PG |
03-09-2018, 12:23 PM | #2 |
Moderator
Re: How do you confirm matching numbers on a 72 k5?
You don’t
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
03-09-2018, 04:13 PM | #3 |
03-09-2018, 05:10 PM | #4 |
Roadtrip!
All you can do is break down build dates and date codes on your components and see if things match up in sequence.
You can match the frame to the VIN and the glove box door...(if the glove box door spid isn't a repro or missing)
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
03-09-2018, 06:14 PM | #5 |
Carpe manana
Here are code examples from my Blazer: http://67-72chevytrucks.com/vboard/s...8&postcount=60
I believe the protect-o-plate also has the engine code embossed onto it.
03-09-2018, 06:36 PM | #6 |
What does block # VE112832 mean?
I can't figure this out sorry. Stupid me. PG Last edited by PGG; 03-10-2018 at 09:01 AM. |
03-11-2018, 08:02 AM | #7 |
Anyone?
03-11-2018, 09:20 AM | #8 | |
Carpe manana
03-11-2018, 10:24 AM | #9 | |
What does that mean? |
03-11-2018, 11:22 AM | #10 |
Carpe manana
If original it will have a suffix code. Not sure if applicable in your instance or not but per that same website linked above:
"VF292800 - is an example of a over the counter crate engine. "2800" is the last 4 digits of the GM part # for the crate engine assembly. The final digit could be a year code. Another example: A Targetmaster engine (p/n 14009800) built in 1985 could have a code stamped as follows: A0198005 (A = january, 01, 9800 = pn, 5 = 1985)." My green Blazer has a warranty replacement motor/block with a code that begins with "CE..." for counter exchange
03-12-2018, 12:32 PM | #11 | |
03-12-2018, 12:33 PM | #12 |
Its a 4 bolt main and those are all the stampings I could find. Thanks PG
03-12-2018, 12:47 PM | #13 |
I a told its a 77-78 block stamping so it must have been replaced. That sucks since I was told it was original.
Now do I rebuild this or do a LS swap since its way off anyway? PG |
03-12-2018, 12:54 PM | #14 |
You're right, that block casting is a late 70's 350. The stamping Deadhead is referring to is in front of the right cylinder head, just above the water pump mounting. He has a good pic in his link. You never know it could be a "Corvette" engine
03-12-2018, 11:01 PM | #15 |
Carpe manana
Free from the albatross of an original motor might as well go LS IMO with an OD transmission.
