Rear end lowering 61 apache
I’m working on my 61 apache shortbox fleetside,my frame is sandblasted ready for some minor fixing and then ready for paint,I was wondering what is the most I can lower the rear of the truck with stock frame,im new to this site so any help would be awesome !
Re: Rear end lowering 61 apache
I wouldn't go much lower than 5.5 but I know some have done 6. When I tried 6 my axles hit the frame with no bump stops when going over big bumps.
I’m putting a front crossmember from a 79,what would I have to do to it to make the truck sit level ,does anybody have any pictures of shortbox with 5 inch drop in back
Here is mine with a 5 inch drop in the rear. If you want it to sit level I think you need a 3 inch drop up front but don't quote me on that. Mine does not sit level. sorry mines a stepper not a fleet
I like the ride height,and you’re truck,looks awesome,did you change you’re front cross member
Yes I have a 77 front cross member with 2 inch drop spindles and 2 inch drop coils. The rear sits a little lower now because I installed the wood and the bumper after that photo was taken. If I were you I would keep the torsion bar suspension if you are not planning on installing air bags. The ride is about the same. If I were you I would get a set of drop spindles with disc brakes and lower it the rest of the way using the torsion bars. If you are going to lower the rear 5 inches I would use 2 inch drop block and 3 inch drop coils. This will give you more travel and longer shocks than if you used a 5 inch lowering spring.
I probably would have kept the original cross member but it had some big cracks in it,so that was the easiest fix for it
![]() Join Date: Oct 2017
When you do a drop spindle with disk brakes does it still work with stock 15" wheels?
#9 | |
![]() Join Date: Aug 2017
Just stay away from POL, they are horrible.
Mike 1960 C10 Short Step 235 w/ 3 on the tree 1999 Mazda Miata <- Track Car 2016 Chevrolet Colorado z71 2016 Chevrolet Traverse - Wifes Car 2014 Honda CBR500R <- Also A Dust Collector 2009 Suzuki GSXR600 <- Stolen ![]() |
