Old 03-12-2018, 10:46 PM   #1
ZEKE68
ZEKE68's Avatar
Tightening ignition switch retainer nut
What do you use to tighten the three slot ignition switch retaining nut?
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 03-12-2018, 11:02 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Tightening ignition switch retainer nut
These are available from most parts vendors....
I made my own from a piece of thin wall tubing.
LockDoc
Leon
Old 03-12-2018, 11:30 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Leon's nicer to the bezel nut that I have been. Use his solution and leave the screwdriver and rubber hammer that I used in the tool box. There is a spanner made for this application, but most people don't buy it if they go to a shop for their repairs.
~Steven
Simi Valley, CA
Old 05-14-2022, 07:20 PM   #4
cj847
cj847's Avatar
LockDoc
I can't find this tool on any of the vendor sites. I found the 68-72 tool.
While I'm at it, what about the tool for the other switch bezels?
Thanks for any input.
cj847 is offline   Reply With Quote
Old 05-14-2022, 09:14 PM   #5
LockDoc
LockDoc's Avatar
Evidently you are looking for a tool for the '67 bezel. You will probably have to make one.
For the light and wiper eschuctions I use a pair of needle nose pliers. They really shouldn't be that tight.
LockDoc
Leon
Old 05-14-2022, 09:23 PM   #6
Getter-Done
Getter-Done's Avatar
LockDoc
I was thinking the same thing Leon.
I bet cj847 is hunting for the 67 socket tool.
The Bezel is 1.025 inch inside diameter.
The slots is 1.125 inch maximum inside diameter in 3 places.
They are about 0.100 inch wide.
The depth is just over 3/4 inch.
The early bird gets the worm,
84 Chevy K-20
Old 05-14-2022, 09:41 PM   #7
Getter-Done
This just popped up in the Amason search.
The review says it won't work on Large Bezel???
Link:https://www.amazon.com/Ignition-Swit...8WTTQV5G&psc=1
84 Chevy K-20
Old 03-12-2018, 11:35 PM   #8
jocko
jocko's Avatar
The very first thing you'll do AFTER you hit the screwdriver with a hammer and drag the tip if it all across your dash is rush out and buy the $8 wrench for ignition bezels
Many of them have a little bar welded across the top so you can tighten them sufficiently by hand.
EDIT: one note - be careful the first time you use one with a bar on it - it may hit your dash bezel and scrape the chrome plastic - just be aware, easy to not see it coming...
Old 03-13-2018, 08:33 AM   #9
jmader
jmader's Avatar
Do local parts stores carry these or do they need to be bought online?
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 03-13-2018, 09:03 AM   #10
ZEKE68
ZEKE68's Avatar
The Truck and Car Shop in Orange California has them for $9.00 plus shipping.
Old 03-13-2018, 12:11 PM   #11
LockDoc
LockDoc's Avatar
You would just have to call around and see. Some of them may have them on hand....
LockDoc
Leon
