![]() Join Date: Oct 2014
Question for rear housing gurus
So I advertised my 68 C10 rear end in the for sale section. Housing is stamped HA which is 3.73 gear ratio. A member said he would buy it but only wanted the ring&pinion, carrier etc. I agreed and yesterday pulled the carrier and pinion gear out and lo and behold the thing is a 2.76 gear ratio! It must have a series 2 carrier from a later than 72 12 bolt truck rear? I did some searching and found some one had an '85 truck rear with the 2.76 ratio. Question is will the later carriers inter change with the earlier 67/72 rear housings? Needless to say the sale went south but the buyer was glad I checked before I sent it to him. Pics of parts and housing stamp below. Tooth count on the pinion is 17 and on the ring gear is 47.
Phil "Money is only a tool to create and achieve what you want most in life" PayPal: rodnrudy@comcast.net |
Re: Question for rear housing gurus
HA is 3:73 no listing for 2:76... is a 2:56 and 2:73 ,but your gear tooth count matches none of them....
Stan 67 swb BLU MULE posted via flip-fone |
I typed "2.76 gear ratio in C10" in the search window and the only posts mentioning that ratio were for later, '75-'85 trucks. One even mentioned the ratio was standard in the diesel C10s. I'm just surprised the 2 series carrier will work in the '67/'72 rear ends. That rear gear would make a good cruising one. Maybe I'll throw it in the for sale section. Lol
My 1981 C10 had a 12 bolt 2.73 ratio rear end.
1968 SWB Step Side, Big Block, 4L80E , Running! |
Six in a row makes it go...
![]() Join Date: Mar 2009
The book shown below, by Randy's Differentials, is one of the best tech books I've ever read.
He lists three carrier variations for the truck 12-bolt: Two-series: 2.56-2.73 Three-series: 2.76-3.42 Four series: 3.73-4.10 I've never encountered a truck two series or a 2.76 in the wild...
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
I would think that would be worth a lot of money. Lots of guys don't have a overdrive trans and would like better fuel milage in their truck. I would buy it myself if I didn't just rebuild mine.
#7 | |
![]() Join Date: Sep 2010
Location: Formerly MD and San Diego, now loving life in Arizona
I just discovered my '69 has a 3.07 limited slip installed instead of the HA 3.73 gears. It is good as it keeps the RPM's down on the new 396BB that is in there. Makes for a great cruiser where I am only pulling 2600RPM at 70mph, but terrible at lower RPM performance. When I bought the truck, the PO and my own research showed that the truck had the 3.73 installed, but neither of us actually opened up the rear end to count the teeth.
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
I have a 12 bolt gov lock with a 2.73 ratio. It came out of an 81 I believe.
Thats awesome, I lost the pinion on my posi 3:73 and found a guy selling an open carrier and beautiful 3.07 R&P for $100 on CL.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
