03-13-2018, 06:50 PM | #1 |
Back half , bed floor
Ok i have back halved it
Need some pics and experienced back halfers ideas on putting wood back in Oh and wheel tub recommendations Thx in advance
1962 chevy short and wide 2015 z71 1967 SS Chevelle |
03-13-2018, 10:15 PM | #2 |
meowMEOWmeowMEOW
Re: Back half , bed floor
I did a rear frame for my 66 last year, and ended up fabricating a multi piece subfloor from aluminum channel, which holds an aluminum bed skin.
Do you have any sections of frame which protrude above the floor height?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
03-13-2018, 11:54 PM | #3 |
Yes and thinking of putting plywood down and covering it in aluminum
03-15-2018, 11:56 AM | #4 |
meowMEOWmeowMEOW
This is the one I built last summer. Still need to finish the notch cover combo.
03-15-2018, 12:36 PM | #5 |
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
03-15-2018, 03:35 PM | #6 |
mini truck racer
Outboard air bag / watts link . Loks of cool stuff going on in that picture^^^^
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
05-01-2018, 07:35 AM | #7 |
I welded tabs on my frame and used 2" x 2", 3/16" thick aluminum angle as cross members to mount my floor to. The tabs will have to vary in height so that the cross members end up at the same top height. Then I mounted my aluminum sheet floor to that. I plan on replacing the aluminum sheet with wood in the next year or so. Placed every 18" (I think), the floor is strong enough to support some load- I would not be concerned about standing on it once I get the wood in.
05-27-2018, 07:21 PM | #8 |
mini truck racer
I will be doing similar . Tabs on the bed sides and the frame . Aluminum angle to mount the wheel tubes . I was told I needed a floor . That a truck with just a bed cover created some lift at the top end due to wind getting under and in the bed area.
