Drum brakes replacement parts?
Ive never done any brake work other than dismantle the ones I have. I had taken this all apart a few years back and saved all the parts thinking to maybe sandblast them but I would think a replacement kit would be a better idea. How can I order the right replacements and rebuild them. And I guess more importantly is this something a newbie can handle you think?
Re: Drum brakes replacement parts?
You can reuse the springs ,just replace the shoes and wheel cylinders .
Yes, certainly a job a newbie can handle. Clean it all up and paint it, throw on some new shoes and wheel cylinders if needed and move on.
Do 1 side at a time. That way you can always look at 1 that is still together.
I'm just glad to be here!
Rock Auto has all the replacement parts. Not sure what year you are working on, but here are the numbers for a 1965 C-10 with 11" x 2" rear drum brakes.
Drums: RAYBESTOS 2005R {#102005, 2005, F2005} Professional Grade; Outside Diameter 12.375" / 6 Bolts / Not Finned Shoes: RAYBESTOS 280PG {#280RP, 280RR} Professional Grade; Organic; 11.00 X 2.00 (Same shoes used on front also) Wheel Cylinder: ACDELCO 18E1123 {#18E444, 19175652, 89052214} Professional Rear - Right Wheel Cylinder: ACDELCO 18E1124 {#18E443, 19175653, 89052213} Professional Rear - Left Hardware Kit: CARLSON H7018 Drum All-In-One Kit Newbie should be able to do it. Take your time and use you picture above as a reference. Should be plenty of You Tube videos to watch too.
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
