PCM is not grounding fans properly
I posted this in the electrical forum as well.
I am working of the relay setup for my engine fans on my LS conversion. I got a dual fan setup with each fan triggered by a relay that is activated by the engine PCM. Each fan has it's own relay. The PCM activates the fan relay by triggering the ground to the relay. My problem is that when the pcm triggers the fan (about 190degrees) that fan only runs 1/2 speed, maybe less. The relay is also rapidly clicking, both relays do this. When I bypass the PCM ground with a wire clipped to a solid ground the fans run at 100% and the relays don't click. So I assuming I have a grounding issue, my problem is I don't know how to improve the ground since it terminates somewhere in the PCM. The fans have their own ground, which I believe is adequate because when I activate the relay by grounding it to the neg battery post the fans work great. When I let the relay be activated by the pcm ground switch the fans don't work so great. Any suggestions?
1977 Chevy C10 SB, Turbo 5.3ls, TH400 |
Re: PCM is not grounding fans properly
Does the case ground on these?
Maybe check resistance from the grounds and negative cable. Might be a bad connector or junction. If I remember there are more than one at the ecu. Also, if you have another brand of relay you could try, it might help.
It was said that if you cut off one hydra head, two more grow back. -Lernaean Hydra Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=743246 |
meowMEOWmeowMEOW
Case is supposed to internally ground, but its a known issue when addressing grounding problems. Run a hard ground off the ecm case (just hold a wire to it and try) and see if it helps.
I'd also make sure you have the little mesh ground strap off the head, as they get lost in swaps sometimes and have been known to cause issues with things like injectors.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Had the exact same problem with the high speed fan output on my EEC. Low speed works perfectly. I ended up triggering the high speed relay via a switch that overrides the low speed relay (and I have yet to need to use it; the fan cools the engine adequately using just the low speed). I would be interested to hear if you find a solution, as I'd love to have the EEC properly control both speeds.
#5 | ||
![]() Join Date: Jul 2009
2005 5.3l with a 1999 pcm. When I had the pcm flashed I had them activate the fans. I added a couple pins to the harness
![]() ![]() Join Date: May 2015
a lot of those early ecm's only controlled a single fan and wouldn't run 2 fans....I had close to the same issue...I had to send my ecm back so they could set it up for dual fans...works fine now...
#8 | |
2002 Suburban DBW 5.3L here. I can confirm that the fan settings are correct in the tune file...I wrote the file. Altering the commanded "ON" temp for the high speed corresponds with the temp at which it attempts to switch to the high speed relay. If it was PWM, how would it receive feedback?
What was done to "set it up"? |
What exact engine are you using? A lot of the later model vehicles use PWM fan control by default, not just on/off.
Could the PCM be using PWM to control the fan speed? That would wind up just cycling the relay and making it buzz/click.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
Yes, the tuner sets the fan(s) on and off in software.
The early trucks (99-05 ish) Didn't use electric fans. Just a big mech fan. So if the PCM is from one of those apps then tuner has to get things right to activate those outputs in the PCM. I have read more than once of guys missing a thing or 2. Specifically the fan output Red C2 33 has to be repurposed in the software. On the trucks is operates a door in the HVAC system, And can cause issues like you state. When you say low speed fan do you mean just one fan running ?
81 short step. Last edited by StorminNorman; 03-20-2018 at 07:33 PM. |
At this point I'm not sure how the fans are suppose to be working. Is there a low speed fan that becomes a high speed fan once the engine hits a certain temp? Is the low speed fan always a low speed fan? And a high speed fan that only runs high? Im just confused on what either fan is suppose to be doing. Going into this I thought the fans ran either 100% or not at all, and were triggered at diff temp. It sounds like they are suppose to be doing something different.
#14 | |
I would email Brendan and have him look at the file to make sure they actually got enabled, he's only human, and things do happen from time to time. Hope this helps.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#15 |
Do you have a 2 relay or 3 relay fan setup ?
The 2 relay type operates each fan independently. Each fan is either 100% on or off. One fan or both fans can be on if the PCM commands it. Uses 2 outputs from PCM. The 3 relay setup runs both fans in series for low speed. Then it runs both in parallel for high speed. They always run together. Uses same 2 outputs from the PCM. Basically the PCM doesn't care which system you use but you have to get the relay wiring right for each type. If your PCM was done by LT1 swap Id be surprised if it isn't done right. That guy knows his stuff
81 short step. |
#16 |
That really depends on what fan arrangement you're running, how you have it wired, and how you're controlling it in the PCM.
In my case, I'm running a two-speed fan. I use pin 42 from the blue connector to trigger the low speed fan relay. I attempted to use pin 33 from the red connector to trigger the high speed fan relay, but that signal kicks on and off rapidly when the coolant temp reaches/exceeds the "ON" temp in the tune file. The low speed works perfectly, turning on and off at the temps I've set in the tune file. I've since ditched the pin 33 output to the high speed relay and instead control that relay via a switch, though I've yet to actually need to use it. |
#17 |
cougar....I don't know what he did to fix the "setup".....I'm not a computer guy..and hate wiring
stormin....my 02 engine had elec fan.... on mine there is no high/low speed on the fans...its either on or off the psi harness is built to run dual fans thru seperate relays...my 02 ecm was only designed for a single fan....like i said...my problem was very much like yours...I sent the ecm back to the tuner and he did whatever he does and fixed it....on mine fan 1 comes on at 175....fan 2 comes on at 185....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 03-20-2018 at 08:57 PM. |
#18 | |
81 short step. |
#19 |
I'll dig around in the tune file more when I get time. If anyone else does their own tuning here, I'd be very curious to know what parameter I've apparently missed. The fact that I can control the temp at which it starts cycling would say that the EEC knows to ground that pin based on the input from the ECT, it just cycles instead of holding steady.
#20 |
After a very quick Google search, it seems this is a common issue.
Solution if you're using HPTuners to write your files: Use version 2.24, go to Systems, then A/C, change the recirculation door to "Fan #2". Only problem for me: I'm using SCT Advantage to write my files. Ugh. |
#21 |
Just in case anyone stumbles across this thread in the future, does their own tuning, and happens to use SCT Advantage...
I believe this would be the parameter that you would need to change from a 1 to a 0 in order to get pin 33 to output a steady ground instead of cycling at the "ON" temp for fan #2. That said, I don't foresee myself getting around to switching the wiring back for the high speed fan relay anytime soon since I haven't had reason to use the high speed yet. |
#22 |
Got info from Brendan, great guy.
Fans are either on 100% or off. First fan on at 201 off at 197 Second fan on 204 of at 201 My obd reader shows the first fan coming on 190. I'm going to check my grounds and wiring once again and see if I can get the clicking to go away.
#23 |
Update in case anyone runs into this in the future. It was mentioned above as well. The wire controlling the low temp relay was the only one clicking. I set it up so that both fans are activated by the hi temp PCM wire. All works good, fans come on about 205, no clicking. I'm not able to backtrack the wires to see if #42 or #33 is the low temp wire. Whatever pin was used for the low temp didn't like the situation.
A delay in my update because the entire drivetrain was swapped from the GMC to a 77 c10
#24 |
So then you're only going to run one fan speed?
#25 |
Yes. Instead of one kicking on at 195 and the other kicking on at 205 they will both kick on at 205. I suspect it will be fine. Is a manual tranny with no A/C.
