03-24-2018, 12:37 PM | #1 |
How low without converting to disc?
Recently picked up a 64 c10. Im mostly familiar with 73-87. How low can I go and by what means if I leave the drums brakes?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
03-24-2018, 01:02 PM | #2 |
Re: How low without converting to disc?
Static drop that is
03-24-2018, 01:43 PM | #3 |
Moderator
I'm not sure brakes have anything to do with lowering a vehicle, what do you think?
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 03-24-2018 at 01:50 PM. |
03-24-2018, 02:40 PM | #4 | ||
Can I keep manual brakes with front disc for the time being?
03-24-2018, 01:59 PM | #5 |
67-72 parts collector,
Brakes do have something to do with lowering.
Because if you want to run drop spindles you have to switch to disc brakes. 3” drop spring is the most I would run with drum brakes. Add a 2.5” drop spindle with disc brakes. Use 63-70 conversion spindles. Direct bolt on. Same price as other spindles.
03-24-2018, 05:10 PM | #6 | |
Moderator
Can you run disc without drop spindles?
03-24-2018, 05:11 PM | #7 |
Sure
03-24-2018, 03:56 PM | #8 |
Manual brakes are fine
03-24-2018, 04:07 PM | #9 |
Cool, thanks for the info.
03-24-2018, 05:23 PM | #10 |
What I was implying is that the drop spindles will gain me another 2-2 1/2 inches lower. BUT aside from doing that how low could I get? I’ve seen a couple pickups online that still have 4 wheel drum brakes and are low as heck and still static dropped but not enough info to know if they used drop springs and cut more coils or how they acheived that stance.
03-24-2018, 10:37 PM | #11 |
static slammed drum brake trucks were probably torched coil springs lol you’ll be glad yo changed to disc eventually anyways.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
03-25-2018, 10:32 AM | #12 |
I just looked at your LS swap thread! Nice job. Too bad photo bucket screwed it up with their pictures sharing crap! What size wheels and tires did you use when you had the steel wheels with thin whitewalls? I love that look. Did you use spacers too? I’ve seen may that sit so far inward.
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU Last edited by UKNOWME; 03-25-2018 at 10:49 AM. |
03-25-2018, 10:51 AM | #13 | |
03-24-2018, 11:14 PM | #14 |
Eventually its getting disc and bags but I need it on the cheap for now. I found c/10 King posted this one that was cut front coils. Ive messaged him to get more details.
03-25-2018, 05:57 AM | #15 |
The lowest drop spring on the market is 4 inch drop springs (Hotchkiss). So that would be the lowest you can go in the front if you don't get drop spindles.
1965 Chevy C-10 350 V8 2003 GMC Sierra Crew Cab 6.0L 4x4 |
03-25-2018, 06:42 PM | #16 |
Isn't there a modification called stepped a arms.
03-25-2018, 07:23 PM | #17 |
When I first bought my truck I dug around for a long time looking for ways to drop the ride height while still keeping drum brakes. I called all the vendors and no one made drop spindles for drum brakes. They all figured that anyone lowering their trucks would want disk brakes. At the time I didn't want to spend an extra grand on drop spindles, new disk brakes, proportioning valve, etc, etc. I was completely happy with my set of well tuned (manual) drum brakes.
So I started with a set of ECE two inch drop springs in front. That didn't quite get me where I wanted so I cut one coil. This dropped me another 2 1/4". I quite frankly would like to go lower still, but now the tie rods are sitting at about as much angle as I am comfortable without doing some steering geometry measurements. Plus I dropped the rear to match the front with 6" ECE springs and I can't go lower there without some type of notch (and relief for the differential). I feel there is more room to go on the fronts without resorting to drop spindles, but you would have to get creative. I would pull the lower a-arms and shave down the lower bump stop brackets. These are definitely getting in the way. There is a perch right behind the bump stops that serves as the steering stop, this could be shaved some as well, but you can't go too far without re-engineering a different stop. I would correct the tie rod angle by flipping the mounting location on the spindle from top to bottom. Using these techniques, I think a 6" drop is feasible. |
03-26-2018, 12:04 AM | #18 | |
At what point do you have to worry about pinion angle and swapping out the trailing arm crossmember?
03-25-2018, 07:59 PM | #19 |
Cris be careful flipping your tie rods to the bottom of the spindle arm
You will create bump steer issues. The tie rod should run parallel to the lower a-arm. Sure you can cut springs as much as possible, but you get alignment issues and a loose spring in the spring pocket with a-arms at full droop. I also think you can get drop spindles and disc brakes for less than a grand up front. $250 for spindles (63-70) a 71-72 m/c, an adjustable prop valve, parts house rotors and calipers or better yet Rock Auto as a source. I’m sure you will need a M/C mount like member CaptainFab sells. Just depends how creative you can get parts shopping.
03-25-2018, 09:23 PM | #20 |
03-26-2018, 12:05 AM | #21 | |
03-26-2018, 02:12 AM | #22 |
Here's how low
03-26-2018, 02:30 AM | #23 |
UKNOWME:
I haven't put my gauge on the pinion angles, but from a practical perspective I have not seen any issues with vibration, etc. The drop as you can see from the pic is not that severe, not like laying frame..... lolife99: Flipping the tie rod mounts to the spindle will reduce the angle, that is, get them more parallel to the A-arm. With the stock location on the spindle, the tie rod angle is starting to get well away from parallel with a 4" drop. Flipping them on the spindle would help correct this. I really should stuff all the a-arm and tie rod dimensions into a suspension program and map it out. but its just a truck that drives around town, not a race car....... I have hammered the truck a bit to see if there are any issues with braking or steering under more severe conditions and have not seen any major issues. |
03-26-2018, 08:37 AM | #24 | |
Unless you are using a stepped a-arm or a raised lower balljoint,... all the pivot points remain the same. The tie rod may be more parallel to the GROUND,... but it is no longer parallel to the lower control arm. Good luck with your project UKNOWME,...
03-26-2018, 08:29 AM | #25 |
Thanks for the pic! Inas hoping for a little lower. Do you know what the overall diameter of those tires are?
