Quadrajunk
My quadrajet is quadrajunk. Isn't there a board member who sells and or rebuilds them??
If not, where is the best place to buy one?? Thanks |
#2 | |
Who Changed This?
![]() Join Date: Jan 2013
Re: Quadrajunk
Ken at Everyday Performance Cliff Ruggles at Cliffshighperformance Mark Harmon at Quadrajet Power are names I know from my Buick experience Any one of these guys can fix that thing like new. If you find someone here, that's cool, too. Not trying to steal anyone's thunder. Is it the original carburetor? It makes a difference, when it comes to getting the job done right. Tell any of these guys the casting number, and they'll tell you what it is from. BUT, if someone has committed a Dr Frankenstein job on it, that could be a problem. HTH I have a Q-Jet on my truck that I've rebuilt using Cliff's kits, and it works like a charm. It's probably the 3rd time I've rebuilt it in the last 30 years, since it used to belong to my father in law and I used to do most of his mechanic work.
![]() Join Date: Dec 2013
Re: Quadrajunk
Rebuild what you already have , https://quadrajetparts.com/rochester...jet-c-128.html
Or just find your local carb shop to rebuild it . ![]() |
#4 | |
Re: Quadrajunk
#5 | |
Re: Quadrajunk
It is not original, the original was stolen before I bought it. It was a junker put on to make it run. Like those buicks had a 68, 70(455), and 3 71's GS's and my wife has a 99 GSE supercharged V6 for her weekend ride. I also still have two 455 engines waiting on a project |
Re: Quadrajunk
Mine is a frankenstein, missing choke parts, I was making it do, but I'm changing engines (to a L31 vortec)and was looking at a edelbrock 2116 so I could use a quad, but I may use an edelbrock EPS and a performer carb. Trying to keep cost down without sacrificing to much quality.
Rebuilt quads at summit are $380 |
Re: Quadrajunk
you can rebuild it and buy the missing choke parts for less than $60.00 , your choice rebuild it or use visa and UPS .
Re: Quadrajunk
![]() Join Date: Jan 2001
Re: Quadrajunk
Here's what I have:
https://www.amazon.com/National-Carb.../dp/B00IA5L362 $240 and runs great right out of the box.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: Apr 2016
Re: Quadrajunk
That's the one I got, except I ordered it directly from national carburetor and sent them my old carb for a core return. They built it for me with 1969 linkage. It was inexpensive and got my truck going. The old carb had both the fuel inlet and needle valve seat threads stripped out, and the damned thing was put back together with baling wire and bubble gum. I was glad to get rid if it.
Re: Quadrajunk
You can take it to a shop that specializes in bench work rebuilds. Most bigger towns and cities will have such a shop that the repair shops take their carbs, starter, alternators, generators, and such to for rebuilds. You can have a QuadraJet rebuilt for half what it costs for a rebuilt over the counter.
When I see "Quadrajunk" it instantly tells me that person knows nothing about 4bbl carburetors. It screams ignorance. Probably a good idea to forget you ever heard that word. It tends to rile me just seeing it. They are one of the best factory production, as well as aftermarket, 4bbl carbs ever made. Not sure there is another 4bbl that can give all a Qjet can, in full spectrum. That spread bore design is right for today with what fuel costs. I've enever had a 4bbl sip as little as a Qjet and still give full power the way they do
#12 | |
Re: Quadrajunk
One of the First
![]() Join Date: Jan 2000
Re: Quadrajunk
I would just go with off the shelf Edelbrock 1801 Thunder Series and matching manifold for your L31. It will get you down the road. The Edelbrock are easy to work on too. They come with instructions on set up and customer support line. Plus they have an electric choke. Rule of thumb, for street driving and mid-performance, use a Quadrajet - mild to wild in two seconds. If want to race or heavy pulling, use a Holley. Edelbrock, use for every day driving, like I mentioned, easy on the brain to mess with. My 2 cents...
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) Last edited by D.PASSMORE; 03-27-2018 at 03:59 PM. |
#14 | |
I have a radical idea!
Re: Quadrajunk
The Street Demon carb that is basically a revised hybrid between a Q-jet and a Thermoquad is the carb I'd choose if I going with an aftermarket carb for a daily driver.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#15 | |
Re: Quadrajunk
The Street Demon carb that is basically a revised hybrid between a Q-jet and a Thermoquad is the carb I'd choose if I going with an aftermarket carb.
#16 |
Re: Quadrajunk
Lars Grimsrud out here in Colorado is known nationally for his QJ knowledge. He can rebuild it for you if you contact him.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED ![]() |
#17 | |
Where's my beer?
Re: Quadrajunk
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
#18 |
Re: Quadrajunk
If you caan't or just don't want to rebuild your own any local carb rebuild shop can handle the task of fixing it for you , Sure there are lot's of "big name " carb guys but for your local daily driver or weekend cruiser you don't need to go any further than your own local carb shop .
#19 |
Re: Quadrajunk
Although I don't have one at the moment, I agree that the Q-jet is an excellent unit, and I hope to have one again someday (other priorities right now).
But I just have to share the name my ex-F-I-L (He was not a fan; then again, he tore up every vehicle he ever owned) gave them: Rottenchester Quadrajunk Carbonator.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#20 |
Re: Quadrajunk
I rebuild them, and have a box full of old ones for parts. But I'm in CA.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
#21 |
![]() Join Date: Aug 2013
Re: Quadrajunk
They are on sale $189.95 plus shipping and core, I just got one for my truck and it runs perfect now.
http://www.nationalcarburetors.com/l...partnum=nd4213 |
#22 | |
Re: Quadrajunk
#23 |
Re: Quadrajunk
Rebuild. They're great carbs
#24 |
![]() Join Date: Feb 2000
Re: Quadrajunk
I just had mine rebuilt and slightly modified by Quadrajet Power in Texas. It was definitely worth it, I highly recommend them.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
#25 |
Moderator
![]() Join Date: May 2007
Re: Quadrajunk
Any carb can work great and any carb can suck...just depends on how well it is tuned. They are all pretty much obsolete anyways, take your pick
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
