Old 03-29-2018, 02:09 PM   #1
bob8619
Jackstands + no wheels = heavy vibration?
Is there something I'm not aware of that would cause heavy vibration when putting the truck in drive while on jack stands and the back wheels removed? Drums are off too.
Does the lack of resistance of the wheels being amplify possible drive line issues or is it just a known thing that running without tires causes vibrations?
1968 C10
bob8619 is offline   Reply With Quote
Old 03-29-2018, 02:25 PM   #2
harpo231
harpo231's Avatar
Re: Jackstands + no wheels = heavy vibration?
Not normal....
Does it shake on the road ?
Stan
67 swb BLU MULE
posted via flip-fone
harpo231 is offline   Reply With Quote
Old 03-30-2018, 12:48 PM   #3
jeffahart
jeffahart's Avatar
This question was never answered, or did I miss it? My take is... who cares! If it performs on the highway under load with no symptoms then I think you are fine. It's a truck... not a pine wood derby car. Get it off the jacks and run it, give it some torque. If it performs, run it. If it vibrates, then chase the problem. Anything else seems to be an exercise!
My two cents, worth the price paid!
j
White K20
jeffahart is offline   Reply With Quote
Old 03-30-2018, 01:06 PM   #4
bob8619
j
Yeah I answered it up there. In a nutshell: It does shake between 50-53 mph. 2 month old tires, been balanced 3 times. Mechanic blames excessive runout, tire shop says he is wrong so wont swap them out for more.
Tried some old tires and got the same feeling at the same rpm but different mph since the tires were smaller. So thinking it was rpm related as opposed to speed, I went into that rpm range while in 2nd gear and it doesn't shake. Thats when I tried without tires and found it shakes even worse without tires.
1968 C10
Old 03-29-2018, 02:30 PM   #5
weq92f
weq92f's Avatar
Well, I've never done that before so I have no direct experience, but... I can't think of any reason why you'd have such a vibration. Even without the wheels, there are quite a few moving parts that could cause the issue. Most suspect in my mind would be the stuff inside the pumpkin, axles, ujoints, drive shaft and components and then up into and through the tranny.
I would first check your u-joints and then your pinion angle.
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 03-29-2018, 02:38 PM   #6
bob8619
I've got a hopping type feeling throughout the cab between 50-53mph give or take a couple. This falls somewhere between 2100-2400 rpms. The tires are cheap but new, my mechanic says its excessive runout on two of the tires so I brought it back to Tire Kingdom but the claim they're fine. I trust my mechanic more than them but they weren't willing to replace them.
I tried two old smaller tires on the front and test drove, same issue at same speed and rpm. Then, I put those tires on the back and the issue persists at the same rpm but now at 47mph. Its always possible though that the 2 smaller tires are out of balance and its only by coincidence that the hopping is occurring at the same rpm range. But anyway because of this test I started to question the driveline . However, if I keep it in 2nd gear and get into that rpm range, it doesn't happen. Only once it gets into 3rd gear.
Since its confusing me I figured I'd just try it without tires on and the rear end jacked up, and thats when I discovered it is worse without tires than with them on. So now I don't know if its tire issue, drive shaft issue or tranny issue.
1968 C10
Old 03-29-2018, 02:41 PM   #7
palallin
U-Joints &/or carrier bearing would be first on my list to eliminate.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 03-29-2018, 02:43 PM   #8
bob8619
My yoke was questionable when I replaced the u joints a few weeks ago, I thought it had it squared away but perhaps I didn't.
1968 C10
Old 03-29-2018, 03:01 PM   #9
bob8619
Heres what I mean by questionable. Its hard to see in the pics but If you notice, the two caps that are going into the yoke are not even, this makes it seem like it would be off center but if you look at where the u joint lines up with that notch in the center of the yoke, it makes it appear as though its centered.
1968 C10
Old 03-29-2018, 06:29 PM   #10
jradford
U-joints and carrier bearing would be the first thing I would check.
jradford is offline   Reply With Quote
Old 03-29-2018, 07:04 PM   #11
Stocker
20' Daredevil (Ret)
Stocker's Avatar
x3, and being on jackstands with the rear wheels off, it seems like you might be able to actually see what's moving around causing the vibration.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-29-2018, 07:13 PM   #12
bob8619
I found that one of the u joint caps in the yoke has side to side play in it. I overnighted a new yoke so we will see if that was the only problem.
1968 C10
Old 03-29-2018, 09:06 PM   #13
That'll do it, not centered as well as unseated bearings in cap. Could it be the needle bearings got dislodged in the cap, causing incomplete bearing with the one or ones that fell out laying in the cap preventing it from seating? Did you get the clips in both sides?
Old 03-30-2018, 06:20 AM   #14
bob8619
I had to modify the clips to get them both in but it wasn't due to the caps not going into the joint completely. I checked and rechecked and the needles hasn't fallen. The caps were seated on the joint completely just appeared to be uneven in the yoke.
1968 C10
Old 03-30-2018, 09:53 AM   #15
100%Chevy
I had some bad vibrations on my 78 C-10.Finally replaced the center carrier bearing and still vibrated(about 60/65 mph).
Found the pinion nut was a little loose!Tightened it up and the problem is gone.
Mike.
100%Chevy is offline   Reply With Quote
Old 03-29-2018, 10:21 PM   #16
Overdriven
I don’t see it mentioned anywhere so I figured I would ask. When running your test on jackstands, is the rear axle on jackstands supporting the weight of the truck as if it were on its wheels?
Overdriven is offline   Reply With Quote
Old 03-30-2018, 06:14 AM   #17
bob8619
Yes
1968 C10
Old 03-30-2018, 10:55 AM   #18
davepl
davepl's Avatar
Assuming stock parts installed and phased correctly, if I ever have another vibration, are the steps I follow regardless, because logic and troubleshooting have always failed me on drivelines:
1) Replace carrier bearing
2) Replace u joints
3) Balance driveshaft
4) Service slip yoke on 2-piece
For me I had to go to #4 (with many other stops along the way) before it got fixed. They said there was wear in the spline, that I couldn't feel. I was highly dubious but they replaced it and the problem went away.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-30-2018, 12:12 PM   #19
bob8619
New yoke came in, installed with new moog joint and no luck , still vibrating. One piece drive shaft so no carrier bearing. U joint at the axle is only a month old and has no play in it so I didn't replace that one today. I guess I'll check the pinion angle and then after that just go get the shaft balanced.
1968 C10
Old 03-30-2018, 01:13 PM   #20
bob8619
When I got the truck the guy had chunks of 2x4s in each of the rear shocks, I didn't think much of it and removed them. These are how the shocks look now, could their condition result in improper driveline angles which could cause the speed/rpm dependent vibrations? Sorry for the sideways pics.
1968 C10
Old 03-30-2018, 01:37 PM   #21
jeffahart
jeffahart's Avatar
OK, happens on the road; that said and that picture! No angle! Post #3 center rendering; the angels cancel each other out. Let's see the front. Or maybe you can get a shot of the whole drive line. You need to get your drive angles correct. As stated above. Unhook the drive shaft and see it it still vibrates. Just so you know! Easy and you can rule out anything up stream. Assume nothing!
j
White K20
Old 03-30-2018, 01:46 PM   #22
jeffahart
jeffahart's Avatar
Also, after you verified, no vibration from upstream. While your shaft is unhooked, whole shaft. Turn the shaft 180 degrees then, Re-install it! You want it connected on different sides of the yokes! Simple test, and it my show progress or degradation. After that.. it's those pesky angles!
j
White K20
Old 03-30-2018, 02:04 PM   #23
bob8619
With the shaft unhooked I get no vibration. I stuck blocks in the springs just to experiment and it seems it moved the vibration up to 53-56mph range now instead of the 50-53. I can't get the whole drive line in one pic but I took 3 pics.
1968 C10
Old 03-30-2018, 03:00 PM   #24
jeffahart
jeffahart's Avatar
I see something new, I see something new! Did it vibrate before that new yoke? Did you turn the shaft? See if that changes anything. I always put my shaft back in the way it came out.
j
White K20
Old 03-30-2018, 03:04 PM   #25
bob8619
j
Yeah the yoke was replaced in attempt to fix this vibration issue. I was able to wiggle one of the u joint caps inside the yoke while it was fully installed so figured it needs to be replaced anyway so just swapped it.
I haven't rotated the shaft 180 since installing it yet no. But as I mentioned in my last post, the raising of the rear end seems to be fixing it or at least masking it.
1968 C10
