Old 04-09-2018, 11:09 PM   #1
72 paul
Tilt Steering column
Who's got a source for switch cover puller j 22708?
72 paul is offline   Reply With Quote
Old 04-09-2018, 11:40 PM   #2
randy500
Re: Tilt Steering column
You can remove the cover with a screwdriver and a hammer, ive done it dozens of times, use your best newest screwdriver with a sharp edge, there is a groove on the bottom I think, cant remember the exact location. Start there then move around. Helps to secure the column is a holding fixture nice and tight. Also use the tilt mechanism to get best access.
You can borrow my puller with a deposit and pay shipping both ways....I would need a $150 deposit....
randy500 is offline   Reply With Quote
Old 04-09-2018, 11:45 PM   #3
randy500
Here is one on ebay, I think the only difference is the pressure bolt is shorter, different part number but It might be the same tool.
https://www.ebay.com/itm/N16B-Kent-M...4383.l4275.c10
Old 04-10-2018, 12:32 AM   #4
72 paul
Thanks for the offer on borrow. Saw the ebay deal,may go for it.Switch is bad gotta get it out.Paul.
Old 04-10-2018, 06:19 AM   #5
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Tilt Steering column
I took mine off without any effort. I twisted and pulled up it came right off.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 04-10-2018, 10:09 AM   #6
72 paul
Be nice to get lucky like that,this ones been rebuilt and is tight.
Old 04-10-2018, 11:49 AM   #7
Andy4639
Old member
Andy4639's Avatar
Where the turn signal are tilt switch comes through slip a screw driver in and pry real easy and see if it moves.
