Top Kick
I have a 1976 C65 With GM 427 Tall block truck engine, 5 speed, two speed rear. It is a gas hog, and severely under powered.
I have bought a fire truck, a 1990 Top kick 7000 with Caterpillar 3208 Turbo V8, Allison transmission. My plan is to move the dump bed to it, and the pintle hitch. Obstacles are hydraulic pump, and drive shaft after I remove the Hale fire pump. I seek advice on pump choices. Electric is available, I don't know how well it will perform. Pto, I'm not sure of as the Allisons may, or may not have a gear to drive it. Belt driven is challenging, no pulley available, or brackets to mount. Linear with crankshaft, the radiator, oil cooler is in the way. Drive shaft: I believe grave yards must exist, Where are they? Oh, I'm in Mid VT between Manchester, and Rutland. Willie B |
Re: Top Kick
any place that sells big truck parts can make or tell you were to have a drive shaft made up . that would be the best i would think .
allision should have pto cover port they have on most for years . and any pics of the units ? last welcome to the site . ![]()
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
Re: Top Kick
I figured the driveshaft to be a simple purchase from a salvage yard. I have lathe, and TIG welder, so I could build it, but hoped for a shortcut.
The window for PTO is at the top slightly to the passenger side in this transmission. I can use it only with alteration to the floor. Again doable, but I hoped for a shortcut. Newer diesels, there are aftermarket companies offering hydraulic kits to belt drive off the engine. This Cat 3208 is long out of production. I haven't yet decided which road to turn down. Electric is easiest, but may not perform well. Willie |
Re: Top Kick
do you have a way to balance that drive shaft ? ? ? if not it can vibrate and cause problems.
if you can fab stuff then a few simple brackets can be made easy to mount a belt driven hydro pump on the engine .
Re: Top Kick
Balance is something I'd be hard pressed to perfect. This would not turn faster than 2300 RPM, I was hoping vibration wouldn't be excessive.
As for belt drive, it has 5 grooves for V belts on the engine crankshaft. The radiator would be in the way of adding more. It uses two for air compressor, two for 200 amp alternator, and one for power steering. The only way I have room for more belt driven implements is move the alternator, add hydraulic, and place an idler between them to guide the back of the V belts. How well that would work, I don't know. |
Re: Top Kick
I had an older International 5 yard dump truck with a DT466, the hydraulic pump was mounted in the front bumper area and driven directly off the crankshaft via a drive shaft. It had splines to enable belt changes since the driveshaft is bolted with the same bolts as the lower pulley. The pros are that the hydraulics are not dependent on a pto, so operational all the time. Cons are that the pump is always being driven. The vehicle was an ex highway maintenance vehicle. For what it’s worth in my experience, the pros very much outweighed the cons.
Re: Top Kick
I have to say I have been impressed with the electric over hydraulic dump trailer my dad got few years ago. We have had a few different dump trucks with pto setups and were skeptical of the electric unit at first but I have dumped 7T of stones out of it 4-5 times in a day before with 0 problems and its nice not to have to idle the truck up every time just to offload.
I would think you could just grab one of the pump assemblies from either a local trailer place or place like northern tools and just retro fit it to your existing cylinder (or cylinders as the case may be) |
#8 | |
Re: Top Kick
![]() Join Date: Feb 2013
Re: Top Kick
Its easy to change the serpentine clutch to a 2 belt airconditioning clutch if that works better.
#10 | |
Re: Top Kick
Willie |
Re: Top Kick
I found a PTO with hydraulic pump It is used, guaranteed to be in good condition. It is from a yard mule. I know nothing about the hydraulic needs of yard mules. I hope it is compatible.
Re: Top Kick
Not sure how big pump and reservoir is on his trailer. Its a Bri-Mar 14ft-14K rated trailer with 2 telescoping cylinders (some call them 2 stage cylinders) that are single acting (power up, gravity down).
Re: Top Kick
It arrived damaged. The PTO was removed from the donor transmission with plasma, or acetylene torch cutting bolts. One bolt hole in the flange is heavily damaged. No word yet from the seller in California.[IMG][IMG]Damage2[/IMG][/IMG]
Re: Top Kick
i FU*KING HATE slasher junk yards
![]() ![]() ![]() ![]() ![]() dam places waste out time and money with that style of work . i had a local junk yard the place i use to work for insisted we buy from them . 1 day i got a alternator that was FROZEN solid . . . then the used rims ware always bent worse than the ones i was trying to swap out for customers . i told them buy a old dead balancer and spin check each rim and watch it . . . . i started getting good rims after this .
#15 |
Re: Top Kick
Today we removed the fire truck body. Lots of wires, plenty of hoses. It all unbolted, but lifting it high enough to clear the wheels was not easy! We used the backhoe to lift the front lift point, enabling me to move left right, front back, and up down. had it been 100 lbs more, I don't think I could have moved it.
The back we lifted with an International 385 farm tractor with loader. These tractors are intended to lift manure, topsoil, feed, and occasional driveway gravel. They weren't built to lift fire truck bodies. Next step is driveshaft. I can build a driveshaft, but I can't precisely balance it. |
#16 |
Re: Top Kick
Seller has yards nationwide they have promised a different unit from another yard to replace the damaged one.
#17 |
Re: Top Kick
Man you gotta take some pictures of t his, sounds really interesting. But I just can't imagine you getting any better mpg out of the Cat.
#18 |
Re: Top Kick
There is more reason than just economy. The cost of purchase, and fit up would buy a lot of gas. VT is nothing but hills, I hope to climb them without so much gearing down, and running at 3600 RPM. This truck is wide open all the time. Empty, the 1976 C65 performs acceptably. Loaded, it works real hard up, or down. Gas mileage is awful![IMG]Fire Truck Cab[/IMG]
I can't figure out how to post here. |
#19 |
Re: Top Kick
You've got some good points. What's really sad is I felt my 327 SBC powered C50 was a bit sluggish when loaded or on hills, and felt that a BBC would fix it.
I guess not. Not sure what I'll do, but when that tired old engine comes out, I'm gonna have to build something strong enough to make the truck giddy up. I couldn't care less about fuel consumption since I don't drive my truck enough. To post pictures, are they in a file on your computer? When replying to this thread, git the "go Advanced" button, below the text box, click a button that says "manage attachments". From here a window will pop up and click any button that says "browse". This will open a search window that can look through any file on your computer, but that can be a bit hard to use, so patiently look for your photo you want to post. Then click "upload". After that post the reply and you're good. |
#20 |
Re: Top Kick
Here is a picture of the fire truck before I took the body off.
#21 |
Re: Top Kick
Here is a picture of the cab.
#22 | |
Re: Top Kick
Still, horsepower is not huge. There are numerous listed horsepower ratings, I think about 230 HP. |
#23 |
Re: Top Kick
Man that thing looks CLEAN. Is there any rust at all?
#24 |
Re: Top Kick
Back of the frame has surface rust, it needs sandblasting.
#25 |
Re: Top Kick
Looks nice!
How did you get the body off? Unbolt and lifted? Or plasma cut it to pieces? Just curious since I am about to tackle a similar operation on a 69 C50 former fire truck.
1963 Olson Grumman Bread Van - Possible Suburban Swap (sporadically worked on to strip paint) 1969 GMC C10 Pickup SWB Stepside (heart transplant) 1969 Chevy C50 Fire Truck converted to Utility Truck being built into Pickup Truck (newest addition, accumulating spare parts) 1972 GMC K5 Blazer 4x4 (sporadically being worked on, accumulating parts) |
