Electric fan install details wanted
Going to install single electric fan. Looking for details on which wiring kit I should get to work correctly.
SBC 350 stock (HEI upgrade) Aluminum radiator 195 degree thermostat Unsure about a 200 on and 185 off. Unsure if I need a 30, 40 or 50 amp. Never done this before and can use all help I can get. TIA
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice |
Re: Electric fan install details wanted
It depends on the amp draw of the fans themselves so you may have to look at the manufacturers specifications. I have the windstar fans on my truck and my Chevelle. I used the 40 amp ones and the only issue I have is that the truck has toasted two relays in 8 years. I carry a spare in the truck right now.
#3 | |
OutOfMyMind & I'llNeverKnowWhy
I use a Tyco 75 amp relay. No problems with my Mark VIII fan I installed.
If your t-stat is 195° and the fan switch shut off is 185°, once the fan comes on, it will never shut off. Either use a 180° t-stat or a higher temp switch.
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
A lower temp switch? Can you be more specific? Lower as I can think of would be like 185 on 170 off. Is that what your are referring to?
Oops, a typo. I meant to say higher temp switch. I have a 195° t-stat and a switch that's 220° on/205° off.
#7 | |
So, should a 50 amp relay be sufficient? Searched and not finding any for 220/205. Finding a lot of 200/185 or 185/170 and 185/165. In need of a little more help.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet Mopar by Birth Chevy by Choice Last edited by Bandit130; 04-14-2018 at 09:39 PM. |
The accuracy of these switches live a lot to be desired. I've tried many brands, and they all seem to have poor quality control. Either dont work or the temps are wrong. I've had them bad out of the box. Another died while I was on the emissions dyno. Luckily I caught it before the gauge got to the red and turned on the a/c.
That's another thing, if you have a/c, you want the fan to kick on when the a/c is on. One thing to consider is placement. I could not put my switch in the head since it interfered with my headers, so I put in in the t-stat housing. Here's the switch I have, AC Delco 14043275.
I found this one at Jegs that states 200 on-185 off for a 195 thermostat. Would like opinions about this kit.
http://www.jegs.com/i/JEGS-Performan...10561/10002/-1
#10 | |
I'd get the 200 on 185 off with a 180 tstat for a typical SBC. I like the engine to build to temp than have the water pump and fan do it's job. For a relay most fans want a 30amp unless your running a super high CFM fan or your fan is starting to sh_t the bed. It's that initial ON spike that kicks the relay. I have used that kit on a few builds, it is fine for most setups, just make sure your fan does not need more than a 30 amp initial draw. I'd also throw a spare relay in the glove box, most of these are chiniseium and while the larger percentage are fine you don't want a $5 part stranding you in traffic! |
#11 | |
#13 | |
If you're using a fairly light-drawing fan it ought to work as long as the chineseium parts hold up ![]() If you use that knockoff Bosch cube to drive a heavier-duty contactor instead of running the fan directly it *might* last a long time. |
#14 | |
![]() My setups are a homebrew MarkVIII and an HHR with a continuous-duty solenoid doing the heavy lifting controlled by one scrounged OEM cube relay triggered by an OEM fan switch, put another cube relay in the circuit and it would handle AC ![]() If the weather stays crappy I'll try to get a drawing up, wiring the thing isn't all that hard. Dave Barton over in the Volvo world posted a great PDF that was my jumping off point: http://www.davebarton.com/pdf/coolingfandiagrams.pdf Amp draw depends on what your fan wants, the big draws are momentary so a reasonably sized fusible link or PAL fuse on the 'hot' side is all you need. When I was doing my research the subject of fan switch temperatures and location seemed to generate a *lot* of crosstalk ![]() ![]() I tend to stick with re-purposed OEM stuff, it gets lots of testing before it hits the streets. More later ![]() Last edited by gezn2; 04-15-2018 at 01:07 PM. Reason: Found more info |
#15 |
![]() Join Date: Jun 2016
An electric will never move as much air as the mechanical. Keep that in mind since you live in Texas.
Use a controller from DC Controls. They activate the fan based on the outlet temp of the radiator so it keeps the engine at a stable temperature instead of letting it cycle through 15 degrees for on/off. The fan pulls the heat out of the radiator so that is the temp you should monitor for your controller, not the engine temp. Fan should come on at the point where the radiator isn't able to keep the engine at the thermostat temp.
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
#16 |
I used a tarus fan and a volvo fan controller/relay. I just stuck the tarus fan into the stock 350 shroud and drilled 4 holes and bolted the two together.
https://www.cherokeeforum.com/f67/ta...ay-how-214815/ I am running the original 60 amp alt and I never got around to the temp sensor part and just have it hardwired to always run on low. I do have some sort of thermal circuit breaker wired in as a fuse. My temp gauge is broken (living dangerously) but I've been in stop and go traffic on 90 degree days for over an hour and didnt have any issues. |
#17 |
Stop and go isn't where you need the big flow.
#18 |
UPDATE; I got a 2002 Jeep Grand Cherokee electric fan, a relay kit that is on at 200 off at 180. Picture is where temp gauge reads with or without AC. Needle may move about needle width left or right, no overheating. The gauge use to read at the first mark above cold. I am thinking this is probably a little too hot. Wondering if I replaced the 195 t-stat with a 180 or 185 would bring gauge reading down some?
#19 |
It might. But, it won't stay there if the fan isn't keeping up. That's probably the best way to test it.
