Old 04-14-2018, 03:35 PM   #1
obijuan
Belt routing tbi350 ac compressor
I added the compressor for the vintage air system and the belt lines up but it appears that it might not work as intended. It doesnt seem like there will be enough belt engagement on the power steering pulley.
The belt is physically in line with the rear most pulley but that runs the water pumpand power steering pump. What options do I have to put a belt on this compressor?
Vintage air is closed or I'd be bothering them instead.
1985 k5 396/nv4500/203/205 d60/d70 4.56 42 sx2
1991 V3500 350/4l80/205 60/14 4.10 35 toyos.
obijuan is offline   Reply With Quote
Old 04-14-2018, 03:36 PM   #2
obijuan
Re: Belt routing tbi350 ac compressor
Lined up
Old 04-14-2018, 07:54 PM   #3
v30crewcab
v30crewcab's Avatar
get a longer belt and run it all off that groove?
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 04-14-2018, 09:02 PM   #4
obijuan
There's only 40-45% bent engagement as is. If I run the compressor off it it would not have enough to run the pump.
Old 04-15-2018, 11:11 AM   #5
andyh1956
Hard to tell from photos but is your rear comp groove lined up with p/s pulley?
If so your only other option is to run it w/ alt belt.
Looking at the diagram don't look like they intend for the comp & P/S pump to be run by same belt.
I woulda moved the comp to pass side anyway before trying what they sent you.
When you get hold of VA see if they can help you move comp. You'll be a lot happier later on if you do.
But hurry, it was in the 80s here last week!
andyh1956 is offline   Reply With Quote
Old 04-16-2018, 10:02 AM   #6
Desert1957
Desert1957's Avatar
Look at your pics again, Power steering belt only runs off the crank. Move it to the closest pulley grove toward the engine. This frees up the center water pump pulley grove and crank for the A/C compressor.
Desert
Desert1957 is offline   Reply With Quote
Old 04-16-2018, 10:09 AM   #7
Desert1957
Desert1957's Avatar
Not exactly your setup, but you get the idea I posted above
Name:  1988 burban 438.jpg
Desert
Old 04-16-2018, 10:24 AM   #8
Looks like your AC compressor spacer pushes it back to far to make both pulleys usable. Is the a way to remove the square spacer and move it to the rear compressor bracket. That should move you forward enough to make both groves usable to route all your belts.
Old 04-16-2018, 10:30 AM   #9
obijuan
desert, the pulleys you show are for an ac truck. mine is a non ac truck.
my power steering belt is on the crank and water pump. I physically dont have the last groove that you have in your pictures.
I am going to convert over to the ac style pulleys in order to use the belts as gm intended.
The compressor is fixed in its forward and backward position. can not move it. its fastened to the cylinder head basically.
I have the top left non ac one ton small block set. Why there are four different belt setups for 91 is beyond me.
Old 04-16-2018, 11:03 AM   #10
andyh1956
If you need a P/S pulley w/ two grooves I prolly have one up in the barn I can send you.
Old 04-16-2018, 11:13 AM   #11
Desert1957
Desert1957's Avatar
OK, so lets figure this out. my 87 5.7 is a non A/C truck, do you want pics of my P/S belt routing? It only goes around the crank.
I'm still trying to understand how Vintage air wants you to add an accessory without adding different pulleys with extra groves?
Are you sure it doesn't mention adding different pulleys that are not included in the kit?
Desert
