04-17-2018, 08:38 PM | #1 |
Update on Power Steering Pump Flow Modification
I recently posted my plan for modifying my steering pump to give the steering a firmer, less assisted feel. I ordered a pump output control valve from Turn One Steering, part # PN1115. The stock GM can of ham pump delivers a flow rate of 3.0 gpm. Their PN1115 delivers 1.3 gpm which they advised was too low to allow the power steering box to work properly, and instead special machined one to deliver 2.5 gpm. These guys manufacture stuff for the circle racing crowd.
I installed it today, took 1 hour and the valve cost $40. Boy, am I impressed with the results. My 74 Jimmy now has a wheel feel somewhere between my new Duramax which I like, and my new Traverse which is quite stiff. So if you are dissatisfied with the vagueness of the 70's concept of power steering, here is a cost-effective and easy upgrade to make you feel like you're driving a new truck. |
04-17-2018, 11:14 PM | #2 |
Gentleman Jim Driver
Re: Update on Power Steering Pump Flow Modification
That's awesome. I will have to get one.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
04-18-2018, 07:23 PM | #3 |
Steering feel doesn't come from the flow output from the pump normally.....it is due to the diameter of the torsion bar inside the orbit valve inside the steering box. I guess if your mod works, then great, but the difference in steering feel in vehicles is normally from different torsion bar diameters.
04-18-2018, 09:26 PM | #4 |
This definitely got me interested. Sound like upgrading brakes, there is no easy one part to change to make an upgrade. The pump pressure and flow should be balanced with the box. The boxes from different applications have different torsion bars to change the feel, different ratios to determine the turns lock to lock (and fixed and variable are out there) and different internal stops that could screw up your turning radius.
I found a good article with google... http://www.hotrod.com/articles/ccrp-...g-box-upgrade/
04-20-2018, 10:41 AM | #5 | |
04-20-2018, 12:12 PM | #6 |
By any chance did you take a picture of this new valve?
Stock 75 C10 step side. 350 2 BBL, 350 trans. 150K miles. |
04-20-2018, 02:47 PM | #7 |
wow this sounds great! Can you share any more info / photos or even better video?
I've always wanted to upgrade the steering feel and this sounds like it might be a good option Here's the link to the part Stanski is referring to - but read above as he had them modify it for him https://www.turnone-steering.com/col...low-restrictor
Found my dad's old truck http://67-72chevytrucks.com/vboard/s...d.php?t=563321 Newspaper Article Publishing the quest find my dad's old truck http://www.theglobeandmail.com/globe...ticle12494281/ |
04-20-2018, 04:12 PM | #8 | |
Just to confirm my previous assertions, I took the Jimmy for a long spin again this morning and I am absolutely thrilled with the way it feels, just like a new truck. Best 40 bucks I'll ever spend for sure! |
04-20-2018, 08:01 PM | #9 |
subscribed....thanks for the info!
04-21-2018, 08:11 AM | #10 | |
Thanks |
04-22-2018, 10:41 AM | #11 |
My stock fitting was a 5/8 inverted flare but new valve was o-ring, I know Speedway sells the adapter insert for $10 but I just had a new hose made instead as the original looked like it needed replacement anyways.
04-22-2018, 06:54 PM | #12 |
Now to figure out a way to make it so you don't have to turn the wheel so many times to turn sharply.
