04-22-2018, 05:11 PM | #1 |
No crank help
69 c10 2wd w/ 5.3 & th350...after everything was hooked up...i have no cranking of engine....purple wire at ignition does get power when turning switch to crank...but nothing at the starter wire? Also brake light on gauges turns on when trying to start engine... All fuses good are good....any suggestions?
04-22-2018, 06:16 PM | #2 |
Re: No crank help
Wasn't in park completely...cranking and starting now.......but doesn't stay running....now what?....eng. Light comes on and stays on while it starts and fires up...
04-22-2018, 06:51 PM | #3 |
Re: No crank help
Do you have a way to pull the codes?
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-22-2018, 07:02 PM | #4 |
Re: No crank help
04-22-2018, 09:46 PM | #5 |
Re: No crank help
Did you have the VATS disabled in the ECM?
04-22-2018, 09:55 PM | #6 |
Re: No crank help
It was supposed to...but the way things have gone with these guys...i wouldn't be surprised if the ecm wasn't done correctly. Any way to tell for sure once i get a scanner?...
04-22-2018, 10:08 PM | #7 |
Re: No crank help
Don't know about a scanner, but it is exhibiting what motors do when the VATS isn't deleted.
Before I pulled the ECM and had the VATS checked, I'd make sure I had a steady pressure on the fuel rail and make sure it isn't simply running out of fuel. |
04-22-2018, 10:12 PM | #8 |
Re: No crank help
By just disconnecting fuel line?...
04-22-2018, 10:17 PM | #9 |
Re: No crank help
There are codes for the passlock type VATS. Try your scanner and see what comes up
04-22-2018, 10:21 PM | #10 |
Re: No crank help
I'd put a gauge on the schrader valve on the fuel rail and watch what happens when you try to start it. I should stay pretty solid at about 57 or 58 psi. (IIRC) at all times.
If you don't have a fuel pressure gauge, most Autozones have them in their tool loan program |
04-22-2018, 10:24 PM | #11 | |
Re: No crank help
04-22-2018, 10:33 PM | #12 |
Re: No crank help
Just to clear up a little confusion.
Assuming that you had the VATS deleted, it could be exhibiting the same symptoms if you were not pushing enough fuel to the rail and the pressure drooped out - bad pump, stuck regulator, whatever. I don't know if VATS turns off the fuel pump as part of the start denial - but I'd think it would. so you might want to put a test light to the fuel pump too and make sure it is continuously powered and it isn't VATS turning off the fuel. |
04-22-2018, 10:42 PM | #13 |
Re: No crank help
Great info sir...i will follow your advice first before i start with ecm.
04-22-2018, 10:55 PM | #14 |
Re: No crank help
Ok I'm confused. You said it wouldnt stay running, then said that the check engine light is on when it runs? I thought you meant you could keep it running? How long is it running? If never more than a couple of seconds then I'd say it is VATS.
04-23-2018, 12:03 AM | #15 |
Re: No crank help
yes...it only stays on for a second or 2...the eng. Light is on when switch is turned on, cranking...and for the second it is on...
04-23-2018, 04:08 AM | #16 |
Re: No crank help
That sounds EXACTLY like VATS hasnt been tuned out......
04-23-2018, 09:22 AM | #17 |
Re: No crank help
Does the VATS trick work?...Read about swapping ECM with a truck and putting mine in place while turning ignition on and off....does this work?...
04-24-2018, 12:50 AM | #18 |
Re: No crank help
Anyone try this?...
04-24-2018, 01:56 AM | #19 |
Re: No crank help
You have to have a running truck with the same computer from what I've seen, but never tried it myself.
04-24-2018, 03:58 PM | #20 |
Re: No crank help
Only cause I'm not in a rush and about done with project...I will track a truck down and try this before sending ECM off.
