Old 04-26-2018, 11:20 AM   #1
davepl
davepl's Avatar
NPT to steel line - Hey I can edit subject lines in place, I didn't know that!
I'm looking at an EFI pump module that uses an in-tank Walbro pump. It then has 1/4" NPT supply and return fittings.
I would like to use TWO factory fuel lines, one for the pressure side and then the duplicate right along side it as the return.
What's my shortest path to get from 1/4" NPT to braided flex and then to steel line? In other words, how to connect braided hoses to a steel fuel line.
I was thinking:
NTP -> NTP-6AN -> 6AN union -> tube nut on line
It's connecting to the 3/8" hard stainless fuel line that I'm most concerned about. I have the hydraulic flaring tool AND I ever have the 37 degree flaring pieces, so in theory I should have what I need.
I'm trying to avoid ANY rubber in the EFI system, so that's why I'm trying to go NPT to AN to braided line to hard line.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 04-26-2018, 11:40 AM   #2
HO455
HO455's Avatar
Re: NPT to steel line
The most direct way would be to go to a hydraulic shop and have them make you two hoses with the fittings you want on the ends. These guys have done some for me.
http://www.ofsco.net
RIP Bob Parks.
Old 04-26-2018, 11:43 AM   #3
davepl
davepl's Avatar
Yeah, but that doesn't help me connect it to the hard line. That's the hard part. Flaring in place with a 37 degree tool with a tube nut and so on... that's the part I have no idea about.
This guy is doing it I think:
https://www.youtube.com/watch?v=46hF...projectgattago
Old 04-26-2018, 12:01 PM   #4
HO455
HO455's Avatar
Re: NPT to steel line - Hey I can edit subject lines in place, I didn't know that!
I would do double flares on the hard lines with male fittings before installing them. Then use a female inverted flare fitting crimped to the hose. Like the one shown. I believe you can get them in a 45* or a 90* versions too.
RIP Bob Parks.
Old 04-26-2018, 12:47 PM   #5
Benjamin
Benjamin's Avatar
I ran into a similar problem recently. subscribed.
1972 K10, 350/SM465/NP205, 4 inch lift, 35x12.50s on 15x10 wheels
1976 K20 crew cab, 350/Ranger/SM465/NP205
Benjamin is offline   Reply With Quote
Old 04-26-2018, 11:59 AM   #6
Rickysnickers
Will any of these work? https://www.holley.com/brands/earls/...o_an_adapters/
Old 04-26-2018, 12:00 PM   #7
davepl
davepl's Avatar
Here's what I wound up ordering:
TanksInc Pump module with 1/4" NPT inlet and outlet
1/4" NPT to -6AN male
-6AN hose end
-6AN hose
-6AN hose end
-6AN male to male union
-6AN tube nut and sleeve
3/8" stainless hard line
Old 04-26-2018, 01:08 PM   #8
davepl
davepl's Avatar
HO455, how do you put a male end on a hose? I was going to use the standard single-flare with tube nut and sleve (where you can't double flare)
Old 04-26-2018, 01:27 PM   #9
HO455
HO455's Avatar
I am assuming you mean male 45* inverted flare? Looks like these.
RIP Bob Parks.
Old 04-26-2018, 07:48 PM   #10
binford
Are you running a TBI?
Earl's makes NPT to AN fittings
That will work with the flex hose.
Use some type of PTFE liner as it will last forever
Double flares connection are a pain and I find I have to make a few practice ones first on some scrap tubing.
There is a local shop that has a machine he uses for making SS brake lines. Perfect flare everytime
Dorman make a TBI kit, that is steel and about 20" long with flared connection on both ends
binford is offline   Reply With Quote
Old 04-27-2018, 07:54 AM   #11
MARKDTN
Go to a hydraulic shop and you can get hydraulic fittings for steel lines. Don't use hardware store brass compression gas line fittings, they were not made for the high pressure.
https://www.discounthydraulichose.co...tings_s/51.htm
Something like these.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 04-27-2018, 09:25 AM   #12
binford
Thanks for the link, I like those fittings.
Old 04-27-2018, 11:00 AM   #13
davepl
davepl's Avatar
Unfortunately it's an 18 foot steel line that would be pretty tough to take out of the car and haul anywhere! I kinda have to do this one in the car, at least for the existing line.
I've always wondered about brass fittings. The factory uses brass fittings in the brake system. That doesn't mean Home Depot is your hot ticket for factory fittings, but I can't think of any downside to using a potable water fitting if it's NPT. No idea about compression. But all my compression stuff is 37 degree AN anyway.
Old 04-27-2018, 12:28 PM   #14
binford
Dave check out the link Mark posted.
I've used these type of connectors before.
The advantage is less parts used and no flare needed
I've used brass fittings before, but on my current build I will be using theses
https://www.discounthydraulichose.co...7208-06-06.htm
https://www.discounthydraulichose.co...7205-06-02.htm
Old 04-27-2018, 04:04 PM   #15
HO455
HO455's Avatar
I used Aeroquip compression fittings to replace the little rubber hose in the middle of the fuel line on my Burban. I really didn't want to try and flare the ends in place. Worked well.
RIP Bob Parks.
Old 04-27-2018, 11:10 PM   #16
sprint_9
sprint_9's Avatar
This is the type of fitting setup you are after I believe.
Also make sure your AN hose is more than a braided rubber hose. I used PTFE hose.
sprint_9 is offline   Reply With Quote
Old 04-27-2018, 11:20 PM   #17
72Cheyenne454
72Cheyenne454's Avatar
I've used Swagelok fittings before. Take a look at their website...
https://www.swagelok.com/en/product
72Cheyenne454 is offline   Reply With Quote
