Old 04-26-2018, 11:56 AM   #1
thedudeabides86
Active Member
thedudeabides86's Avatar
So, what should I do from here?
Hey everybody. Hope all is well out in truck land. So, here's the deal. I'm replacing the dash pad on the ol Green Beast and I've removed the gauge cluster. What would you all do before you put it back in place? The face of the panel could use a touch up and there's a lot of dust, dirt, and a few gauges that may not work properly. Is there a way to put some power to the gauge itself to see if they are operable? I see that the windshield wiper motor is back behind the cluster. Has anyone had any luck putting in a motor with delay capabilities? Other than that, I just thought I'd get some opinions since I have it out, I might want to do a few things before putting it all back and having to fix something else later. I love these trucks and how easy they are to work on. This is a tedious little project, swapping out this dash pad. I've posted a couple of pictures for viewing pleasure. Thanks for reading.
The Dude abides.
thedudeabides86 is offline   Reply With Quote
Old 04-26-2018, 12:31 PM   #2
HO455
HO455's Avatar
Re: So, what should I do from here?
This is the only complete replacement I know of. There are several ways of doing it with a stock motor that are cheaper.
https://newportwipers.com/product/19...k/#wiper-motor
RIP Bob Parks.
Old 04-26-2018, 01:07 PM   #3
thedudeabides86
Active Member
HO455,
Thanks for the input. The wipers do work and I don't ever foresee driving this out in a hard rain much. I'll save my dough and put that money into the real problems I've got.
The Dude abides.
Old 04-26-2018, 01:19 PM   #4
demian5
demian5's Avatar
Replace the bezel (cheap enough) and if your defroster vents are broken, do those too. Good time to clean and wax the dash and lube the cables for the heater controls.
And you may need to slot the holes in the dash for the pad studs to get it to fit.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 04-26-2018, 01:42 PM   #5
HO455
HO455's Avatar
Heater cable lubing as previously recommended, inspect the heater switch, the heater resistor, the cigarette lighter wiring and the ignition switch wiring. They may have been over heated at some time in the past. I would also do a careful inspection of the bottom of cowl for rust and touch up the paint if it is failing.
P.S. if you have access to the dimmer switch its wiring is another problem area worth looking at.
RIP Bob Parks.
Old 04-26-2018, 02:22 PM   #6
thedudeabides86
Active Member
I've got a cigarette lighter coming from LMC as well as a new glove box insert. There's a lot of dust and dirt in the dash as this truck went through the flood of 1997 when the Red River flooded Grand Forks, ND. The water never made it up into the dash, but the floor was submerged. It's amazing to me that the truck as a whole is as sound as it is since it sat in water for 2 weeks. I'm planning to redo the cab floor with the sound and heat padding at some time. I'll certainly check the underside of the dash for the rust and paint issues. The wiring to the ignition seems good, but the ignition itself seems to be a tad loose. There must be a nut in there to tighten it down, I'm sure.
The Dude abides.
Old 04-26-2018, 02:26 PM   #7
HO455
HO455's Avatar
This is what I used on mine. Any bike cable lube will work well
RIP Bob Parks.
Old 04-26-2018, 02:42 PM   #8
thedudeabides86
Active Member
Nice! I think I have a bottle of that. I'll get to that tonight after the kids are in bed. That gives me time for beer and truck work. Ha!
The Dude abides.
Old 04-26-2018, 02:13 PM   #9
thedudeabides86
Active Member
demian5,
Thanks for the input. I know the whole defroster/heat system hasn't worked for years, so that's something I've got to work on and those cables and the whole unit are accessible from under the dash at the unit. Do you know of the bezel being sold separately from the entire gauge cluster itself? I'm looking on LMC for the bezel (just the clear plastic covering, right?) and I'm not seeing a part number for it as a sole unit. Any suggestions as to what wax you'd use for the dash and what you'd use to lube the heater cables? The defroster vents seem to just sit in the holes on the top of the dash, so those can be replaced pretty easily.
The Dude abides.
Old 04-26-2018, 04:15 PM   #10
demian5
demian5's Avatar
Originally Posted by thedudeabides86 View Post
demian5,
#1 or #2
http://www.lmctruck.com/features/cb/cbcc.htm
And if you aren't familiar with the defroster vents, the replacements fit like crap, hence the reason I mentioned if they need replacement...
1986 C20 Scottsdale
Instagram: C10sofOC
Old 04-26-2018, 06:02 PM   #11
'68OrangeSunshine
'68OrangeSunshine's Avatar
If you pull the instrument panel apart, be very careful cleaning the plexiglas lens. Use canned air and light dusting sweeps with a feather duster. Any moisture will wash away the lettering.
Old 04-26-2018, 02:34 PM   #12
slowcpe
slowcpe's Avatar
As far as gauges a new bezel is cheap and makes a huge difference.
My last two gauge sets I've take them apart, cleaned everything real well, installed LED bulbs, painted the needles orange, and used Meguires headlight restorer on the lens. Makes a huge difference for little investment.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 04-26-2018, 02:46 PM   #13
thedudeabides86
Active Member
I asked this above, but is the bezel something I can buy that doesn't require me buying a whole new cluster? With installing LED's, did you have to do any modifications? I think if I followed correctly, if you change your head or tails lights over to LED's, you had to put in some sort of mechanism in line with the wiring to convert it. Can you pickup any kind of orange paint at a parts store or is it best to get paint designated for needles?
The Dude abides.
Old 04-26-2018, 02:53 PM   #14
slowcpe
slowcpe's Avatar
Yes you can just buy the bezel, its usually $35-45 at most places. I found a thread on here a while ago on bulb model numbers and ordered everything from SuperBrightLEDs. It was pretty plug and play and made a huge difference in brightness. I used fluorescent orange spray paint and a paper towel with a hole in it.
Ryan
Old 04-26-2018, 03:04 PM   #15
thedudeabides86
Active Member
[quote=slowcpe;8248326]Yes you can just buy the bezel, its usually $35-45 at most places. I found a thread on here a while ago on bulb model numbers and ordered everything from SuperBrightLEDs. It was pretty plug and play and made a huge difference in brightness. I used fluorescent orange spray paint and a paper towel with a hole in it.
I think I actually just found the bezel on LMC for $40. That's a sharp gauge cluster there. I'm all excited to get home and get to work now. Thanks for the pointers. I'll have to follow up with before and after photos when I'm done.
The Dude abides.
Old 04-26-2018, 03:11 PM   #16
HO455
HO455's Avatar
The drawback of LED bulbs is you can't dim them. Which if your not driving in rural areas probably isn't an issue. But for me it is nice to dim the dash when driving the highways of eastern Oregon after dark.
RIP Bob Parks.
Old 04-26-2018, 03:12 PM   #17
thedudeabides86
Active Member
Ugh......
So, you'll all have to forgive me as I had an idiot moment. The "bezel" is the black and chrome part of the cluster. The "instrument lens" is just that. The clear plastic that sits over the gauges themselves.
Alright, I've done enough adulting for today. It seems as though my brain is mush.
The Dude abides.
Old 04-26-2018, 03:55 PM   #18
87Skier
87Skier's Avatar
Along with the bezel, I would either refresh or replace the circuit board. You can add a pinch of salt to 1/2 oz. lemon juice, and use a q-tip to clean the copper. Check the bulb holders too. You can buy new ones or clean these and make sure the tabs are out far enough to get proper contact.
I added grounds to my gauges while I had it apart too. It might be overkill, but we all know how good the grounding is in older vehicles.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205
1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears
1996 Chevy Suburban K1500 350/4L60E
87Skier is offline   Reply With Quote
Old 04-26-2018, 06:38 PM   #19
CC69Rat
CC69Rat's Avatar
Youll be really surprised at what toothpaste and a little rubbing will do to the lens. The micro polishing of the toothpaste will bring that haze out of the original lens and you can save yourself that $35.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 04-26-2018, 07:36 PM   #20
clay68c10
clay68c10's Avatar
****Only polish the outside of the lens****
You will rapidly polish off the lettering on the inside.
If you do clean the inside, use a slightly (water) damp very soft cloth and the lightest touch known to man. This method has worked for me. Same with the gauge faces. It is possible to clean those surfaces, just be careful.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 05-01-2018, 10:52 AM   #21
thedudeabides86
Active Member
Re: So, what should I do from here? *Update*
So, here's an update on the changing of the dash pad. Perhaps some of you have encountered this before.
I'm all set to install the dash pad from Brothers who get them from Dashes Direct.
https://www.brotherstrucks.com/67-72...tinfo/PAD7200/
What I didn't realize is that the original dash pad made in the good ol' 70's U.S of A, was course thread. Enter Chinese made dash pad with fine thread, most likely, metric studs. Does Brothers or Dashes Direct provide the fine thread nuts for said Chinese dash pad? Of course they do not. They'll sell you the cheap screws that go in the front of the dash pad, but not the fine thread nuts.When you're in your garage with a cold beer at 9:38pm and the hardware store down the street is closed, your work is stalled because you need said nuts. I tried calling Brothers a few minutes before this post and I was caller number 27. Seriously.
Any who, I'll get off my soap box now. I'll get pictures posted once I'm all done. Thanks again for all the input.
The Dude abides.
Old 05-01-2018, 10:56 AM   #22
thedudeabides86
Active Member
I also forgot to ask about a light bulb that's inline with wires that comes down the bottom of the steering column. It seats in the back of the gauge cluster, but I'm not sure what part of the gauges it would illuminate. Anyone have an idea? I'm guessing with the length of the cable it's attached to, it illuminates the temp gauge?
The Dude abides.
Old 05-01-2018, 11:10 AM   #23
davepl
davepl's Avatar
This is my Pontiac dash, but throwing it out there because I just converted the illumination to LED. Pretty much every modern LED replacement I've found for 194s will dim these days.
Here are three different styles of LED, the second ones being blue. I prefer the last one, which is a bright white 194 LED replacement.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-01-2018, 11:38 AM   #24
thedudeabides86
Active Member
I like that last one too. Is it pretty tedious to convert over to LEDs?
The Dude abides.
