04-28-2018, 10:43 AM | #1 |
Need 1965 C10 seat belt bolt locations
I am wrapping up my 1965 C10 and need the locations for the seat belts. The sheet metal on the cab I picked up was redone and there is no indication where the bolts go.
Do the inboard belts (I assume the buckles) share a common bolt attachment? If you could either post a few pictures or email me (markbritt at Hotmail dot com), I would really appreciate it. I am looking to install and wrap up this weekend. Mark |
04-28-2018, 11:33 AM | #2 |
Moderator
Re: Need 1965 C10 seat belt bolt locations
You probably have them (holes) on the middle of the seat area in the back already. 65's didnt have shoulder belts. This shows the outer areas: http://67-72chevytrucks.com/vboard/s...d.php?t=476066
Here is some info on manufacturers: http://67-72chevytrucks.com/vboard/s...d.php?t=643107 Go to the FAQ section under - Seat Belts - there are many threads: http://67-72chevytrucks.com/vboard/s...d.php?t=646002
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 04-28-2018 at 11:43 AM. |
04-30-2018, 11:34 AM | #3 |
I didn't think these trucks had seatbelts unless you added them. My '66 didn't have them.
04-30-2018, 12:38 PM | #4 |
Moderator
Seat belts maybe - Holes yes.
04-30-2018, 09:33 PM | #5 |
I have a 66 it has the holes.
04-30-2018, 09:38 PM | #6 |
For what it's worth;
My 66 c10 had holes and belts My 65 k10 had no holes or belts Both were unmolested Fremont trucks purchased from original owners, hope this helps To answer original question, the inboard belts do not share a bolt, as I recall there was about a 12inch gap between them ( sorry no pictures )
65 short stepside K10 292-SM420-T221 8 lug closed D44 front NoSpin HO72 4.10 rear Last edited by Short 3/4; 04-30-2018 at 09:44 PM. Reason: incompleat answer |
05-01-2018, 06:01 AM | #7 |
Check The Champ, Demonstrator
If the link works below for my literature, look for the 63 Custom Accessories Installation Manual. The measurements are there for the installation.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
05-01-2018, 06:16 AM | #8 |
seat belts weren't federally required until 1968.. my 65 has no hint of seat belt mountings.. I did order a belt set for it and back then there was a thread with location dimensions and drawings from a 66 in this board.. if I can find it, I'll repost, but it is in here.. thanks to Doug at SMS, took almost two years to get my seat done so that was all paused and belts aren't in mine yet
good luck!
I started out with nothing - and I still have most of it |
05-01-2018, 10:20 AM | #9 |
Moderator
Wow you have been doing some collecting there - Even seat-belt location dimensions and drawings.
05-01-2018, 10:33 AM | #10 |
this is the thread with pictures and dimensions I found a while back;
DIY 3 Point Seat Belt Installation 1960-66 Cab good luck!
05-01-2018, 12:37 PM | #11 |
Moderator
Where he is making his hole for one of the two center holes - I have those holes that I believe are from the factory due to the backing plates shown. Both are 7/16" fine thread.
