04-30-2018, 06:03 AM | #1 |
Urgent help needed
Hi guys I am about to buy a 69 c10 cab but I am unsure about the holes around the inside of back window see photo
Can anyone shed some light for me before I buy it.
Toy list 1969 RS SS BB Camaro 1969 C10 Custom on its way downunder |
04-30-2018, 07:27 AM | #2 |
67-72 parts collector,…
Re: Urgent help needed
Probably was for a camper shell boot.
They usually had snaps in those holes to attach the boot. Made the camper shell a "pass through" with no rear window.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 04-30-2018 at 12:08 PM. |
04-30-2018, 07:33 AM | #3 |
Active Member
lolife99 is prob right, I was thinking snaps for a sun shade or something, do you know if it was from a C/30 chassis
04-30-2018, 07:31 AM | #4 |
Active Member
I have never seen that before.
Probably just some custom work from a previous owner |
04-30-2018, 08:39 AM | #5 |
My truck had a shell most of it's life and has the exact same holes. It is from a boot like mentioned above. Remove the back window and put the padded boot in between the camper shell and the cab for easy access.
04-30-2018, 09:14 AM | #6 |
All but my current 3/4 ton had these - very common. Snaps for a camper boot as stated. If you’re ok with them, then no problem. But a good bit of work to weld em up if you’re not.
05-01-2018, 05:46 AM | #7 |
Thanks guys.
05-14-2018, 04:37 PM | #8 |
Farmtruck desciple
Inside the cab = curtains
Outside the cab = camper seal |
