Old 05-07-2018, 10:19 PM   #1
JayWhiz
64' C10 Pitman Arm
Hello Team,
Well I am at the point of starting my power steering conversion/upgrade and have come to a small stop. I purchased Cardone 27-7512 P/S gearbox along with Cap'n Fab's adapter kit but did not purchase the pitman arm. From what I have been reading the pitman arm needs to coincide with the P/S gearbox. Not sure if this is true or not so I'm reaching out for a life line here. Would anyone know which pitman arm I need to purchase? Thanks in advanced folks, and happy Monday!!!
JayWhiz is offline   Reply With Quote
Old 05-07-2018, 11:36 PM   #2
Captainfab
60-66 Nut
Re: 64' C10 Pitman Arm
What is the year application for that steering box? You just need a pitman arm that will work for the year of the steering box.
Old 05-08-2018, 12:20 AM   #3
JayWhiz
The intended application for that gear box is for late 70's Suburbans and Blazer. So if all I need to do is match the Pittman arm to the box then easy day. I appreciate the feedback on this.
Old 05-08-2018, 11:30 PM   #4
Captainfab
60-66 Nut
It's a 2wd box correct?
Old 05-08-2018, 11:52 PM   #5
JayWhiz
I have been unable to tell if this box was intended for 2WD or 4WD as I did not consider that to be a factor prior to purchase. But from what I have been reading its applications include 1977-79 C10 Custom Delux, C10 Cheyenne just to name a few. Summit even has it listed to be compatible with the old Dodge Ramcharger.
Old 05-20-2018, 02:19 PM   #6
65 C20
If you haven't found one yet I believe that a Moog K6143 is what is listed for a '78 C10, power steering.
Double check online to verify.
Cal.
65 C20 is offline   Reply With Quote
