![]() Join Date: Mar 2018
What differential rear end do I have???
I was gonna replace the differential fluid in my new to me 1970 GMC LWB 1/2t. Don't see a drain plug or a fill plug (are they on the front of the differential?
Can we tell by outside pics what kind of gears etc I have? My SPID is long gone (previous owner replaced the glovebox with chrome one). Original seat was replaced also so no paper/sheet in the back of the seat. |
Re: What differential rear end do I have???
12 bolt truck. No drain plug. Fill plug is on passengers side of case in front of axle tube.
Who Changed This?
![]() Join Date: Jan 2013
You have to take the cover off to drain the diff. You can inspect the gears while you are in there.
Thanks guys. That wa s the only pic I had of the truck. After I posted it I figured fill must be on front. So if I have to take the cover off I’m also gonna need a new seal right? Any recommendations as to brand etc? Or just whatever my autozone has??
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
Fel-Pro RDS 13391...Any GL-5 MP Gear Lube in the 80w/90 will work...
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
laying low
![]() Join Date: Mar 2001
turn
Once you get cover off you can get gear ratio from numbers stamped on OD of ring gear. You will also know if it has a limited slip and if so you will need to buy the friction modifier additive.
![]() Join Date: May 2013
I'm not advocating not pulling the cover but if you jack the rear end up, put it in neutral and make a mark on your driveshaft you can make a very close estimate on gear ratio.
In one full rotation of your rear tire the driveshaft mark will go past 0 point X amount of times (short of 3 turns 2:54, just over 3 turns would be 3:04, 3-3/4 would be 3:73 etc.) Backyard trick I picked up when I was a kid... MOD
Chad '71 GMC 2500 Custom Ol Blue '72 Custom Deluxe Highlander Stuffed Olive '73 Trans Am '13 Silverado 2500 Duramax Storm Trooper |
Thanks again everyone for the tips. I usually drive new/newer vehicles, and usually have the maintenance done by a pro. So intentionally getting into stuff like this is not typical for me. haha
But, I want to know that the running gear is OK before I start driving it around and especially if I put my family in it. A good friend of mine who has been working on vehicles for over 50 years is my mentor and though he is kinda tired of working on them, he gives very good and important advice. He said "check and change the rear end oil" so that is getting done. Figure while I'm in there it's important to find out what I have. Might be kind of a Duh question but, I'm guessing it's better to change/fill fluid while it's on level ground? Correct? But to see the side of the gear I may need to jack up the rear wheels to spin the gear?? I usually lift the rear with jack under the pumpkin. Should I put the rear on low jacks, pop cover off, drain, ID the gears, put cover back on, then drop wheels on the ground then add fluid? Also, I've read where some people use a little RTV with the fel-pro gaskets?? Do or don't do that? And if I do, how long should I give the RTV to dry/set before filling with oil? Lastly, what are the torque specs for the rear end bolts? |
20' Daredevil (Ret)
![]() Join Date: May 2003
If you decide to use a gasket sealer (I always do, gives me peace of mind), get Permatex 81182 -- it's made specifically for use with gear oil.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
Some external pics, hoping to get into the differential tonight.
Chiming in. I did this with mine last year, because the gasket failed. A light coat of the permatex will prevent any weeping.
On a side note: Does anyone know where to get an "S-clip" these days? We used to get them when I was a kid (like 35 years ago) The clip will "tighten up" a one wheeler to make a poor man's posi |
![]() Join Date: Nov 2006
forget gasket......... use permatex ultra black rtv. works a lot better as for diff lube use synthetic , you,ll never have to change it again ever. wash rear out with spray starting fluid.
I BELIEVE IN JOHN 3:16 |
#15 |
Moderator
![]() Join Date: May 2007
Light coat of permatex on both sides of gasket. Let it tack over a bit, then install. Bolts do not need much torque at all, whatever service manual says. I’ve never had a leaking diff cover in my life doing it this way.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#16 |
Ok thanks. Don't have a service manual. Did look in the pdf version, couldnt find torque specs for rear end. Friend said not tight, one handed on ratchet close to head of ratchet (if that makes sense).
#17 |
Who Changed This?
Bolt torque for the diff cover is specified on page 464. Dana 60 gets 35 Ft-Lbs.
#18 |
#19 |
No, you have a GM-12T (12-Bolt Truck) What manual are you guys getting page numbers from? My 72 Service Manual dont have page numbers...? 3/8-16 cover bolts get 35 ft lbs, 5/16-18 get 23 ft lbs, and the 1/4-20 cover bolts get 18 ft lbs. Your GM 12T cover bolts get 23 ft lbs. Make sure the cover mating surface is clean and flat, same for the carrier housing. Use a can or two of Brake Clean to spray the inside of the housing clean, dont forget the drip pan. Check your vent while your under there, a clogged vent will lead to seal leaks. Vents located on the top right of the diff housing. Make sure you place jack stands under the axle before you go to work under there. LeddZepp gave a good method for sealing the cover gasket. The Fel-Pro gasket # for the 12T is RDS 13391. "There is no reason not to use a gasket and several reasons why you should"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() Last edited by Ironangel; 05-14-2018 at 11:52 PM. |
#20 |
Who Changed This?
#21 |
12 bolt gm
#22 |
Here are the pics. I've got it all sealed back up, filling it back up tomorrow.
#23 |
Moderator
You have a 3.07 open diff. Non-posi.
43/14 = 3.07 I zoomed in on the numbers.
#24 | |
So 3.07 is gonna be best possible mileage correct? I have a stock 350/350 with edelbrock intake/carb, headers, HD radiator. My plans for this truck is get it driving/stopping 100%. It will be a weekend driver, trips to the dump, home depot etc. With the occasional (maybe 3-4 times a year) trailer pull of another 67-72 GM truck on uhaul trailer. I'm gonna add a curt class 4 hitch and a brake controller. |
#25 |
Ugh!! Leaking!! I knew that diff cover was gonna be a problem.
Should I just order a new chrome one or try to fix this one?? Or load up on the RTV?? I know I'm gonna have to pop the cover off again, drain the oil (do I try to recapture it or buy 2 more quarts?), get a new gasket etc etc. |
