Old 05-11-2018, 06:29 PM   #1
z71se
Anyone regret going front coilovers?
Hey guys, I'm contemplating doing a front Ridetech kit, but I really don't want to make the front end harsh. This truck is a cruiser and currently has a normal 4/6 drop... spindles, Eibach front springs, blown out front shocks, flip kit in the rear with c-notch. The truck actually rides pretty good! Granted, everything needs replacing... shocks, bushings, balljoints, etc etc etc so I was thinking of maybe doing the Ridtech kit BUT it has the solid bushings for the front control arms. Every single other car/ truck/ vehicle that I've ever built where I installed front control arms with anything other than rubber bushings has been a disaster for me. Every expansion joint I hit in the road I can feel through the whole frame, and I wish I had left it stock.
Any feedack from guys that have done the front Ridetech stuff or other tubular a-arms?
77 C10 Silverado SWB - LS Swap, mechanical resto-mod
05 Z71 Silverado RCSB - 5.3L LM7, 76mm turbo, 4L80e
z71se is offline   Reply With Quote
Old 05-11-2018, 06:42 PM   #2
Dads79GMC
Dads79GMC's Avatar
Re: Anyone regret going front coilovers?
Looking forward to some feedback on this general question. Thanks Mike
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 05-12-2018, 01:07 PM   #3
Goats86
Good question, I was considering the QA1 kit, somewhat less $
Goats86 is offline   Reply With Quote
Old 09-12-2018, 04:08 AM   #4
z71se
Bump!
Old 09-12-2018, 01:08 PM   #5
daddyjeep
daddyjeep's Avatar
Originally Posted by z71se View Post
Bump!
Bump... Isn't that the potential problem? Sorry, I have nothing constructive here, but I couldn't help myself.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 09-12-2018, 01:42 PM   #6
RADustin
seems like you answered your own question.
will you feel much more of the road? yes.
Do you like feeling much more of the road? you have already answered no.
The tubular control arms and coil overs won't make it ride any harsher. the only real benefit to coil overs in this application is pre-load is better adjusted. The solid bushings will tighten things up though and transmit road forces to the passengers.
If you like what you have keep it. Get some nice adjustable shocks and rebuild the parts you have with the bushings you like.
1949 Chevy 3100 P/U
http://67-72chevytrucks.com/vboard/s...d.php?t=302780
1976 GMC Sierra Classic C35 CCSB
http://67-72chevytrucks.com/vboard/s...25#post8188825
RADustin is offline   Reply With Quote
