05-17-2018, 11:48 AM | #1 |
Looking for a rear mount tank
Hey I'm looking for a rear tank, preferably EFI ready, and definitely as bolt-in as possible. I see No Limit makes one, and CPP does too. Does anyone have any experience with either one of those? Is there anyone else I should look at? Thanks.
2007 GMC 2500 CCSB LBZ 1991 GMC 1500 RCSB 350 1981 GMC Street Coupe RCSB 454 Last edited by SKR; 05-18-2018 at 01:10 PM. |
05-17-2018, 12:41 PM | #2 |
Re: Looking for a rear mount tank (NOT BOYD WELDING)
A lot of us use an OEM Blazer or Suburban tank. Although this may not be as fancy as the other options you are looking at, but it gets the job done.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
05-17-2018, 01:25 PM | #3 |
1949 Chevy 3100 P/U http://67-72chevytrucks.com/vboard/s...d.php?t=302780 1976 GMC Sierra Classic C35 CCSB http://67-72chevytrucks.com/vboard/s...25#post8188825 |
05-17-2018, 01:34 PM | #4 |
67-72 parts collector,…
GSI Machine Fab just started making these for c10’s.
05-17-2018, 07:04 PM | #5 | ||
I didn't know that, thanks. All their crossmembers and frames and stuff look really nice, so their tanks should be too.
2007 GMC 2500 CCSB LBZ 1991 GMC 1500 RCSB 350 1981 GMC Street Coupe RCSB 454 |
05-17-2018, 07:20 PM | #6 |
I’ve got a bad blazer frame I’ll remove the tank crossmembers and mounting hardware from if anyone is interested.
05-17-2018, 07:21 PM | #7 |
The drawback to the Blazer tank is no baffles. When mine shows less that 1/4 tank (about 8 gallons) and I corner and throttle hard, it can loose fuel for a second.
05-17-2018, 08:14 PM | #8 |
The one out of the 89 Blazer I have with the bad frame was baffled. I’m guessing 87 - up would be as they are FI, but could be wrong.
05-17-2018, 09:52 PM | #9 |
I bought the No Limit tank with an internal pump to simplify my EFI install. It looks to be high quality. Requires you to remove the spare tire holder and rear cross member. The one thing I don't like about it is that the mounting flange is flat for the full length of the tank and the rear frame has a small kick up which makes it look goofy for mounting it. I plan to make some sort of elbow bracket to fill this area up. Won't be visible once bed is back on anyways I'm just being picky. Hopefully I didn't overlook something with it haha. See attached pics.
lowfastnloud |
05-17-2018, 10:50 PM | #10 | |||
05-18-2018, 10:32 AM | #11 |
I got a poly 31 gallon Blazer tank from here http://www.ineedparts.com/heavy-duty...y-gm-en-2.html
It is baffled. |
05-18-2018, 11:58 AM | #12 |
Why not Boyds? Ive used a few of them and always had great luck with them.
1965 C10 LS2/4l70, WHITE, 5/7 DROP LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283 1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E 1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE |
05-18-2018, 12:19 PM | #13 |
Because I got mad and jumped the gun regarding an issue I had, but that has been resolved and I will now be using a Boyd tank.
2007 GMC 2500 CCSB LBZ 1991 GMC 1500 RCSB 350 1981 GMC Street Coupe RCSB 454 Last edited by SKR; 05-18-2018 at 01:09 PM. |
05-19-2018, 03:24 PM | #14 |
Boyd fuel tanks are pretty sweet, you can always go to EFI for when your ready to go that route
