Old 05-23-2018, 08:23 PM   #1
darby555
Door and front clip compatibility.
I was wondering if a 66 c10 door will fit on a 63 cab? Also is the 66's entire front clip compatible with the 63 cab?
I see that the front fenders and hood are the same part numbers but the door and door goass seem to be different between 63 and 66.
Any insight would be appreciated. Thank you.
darby555 is offline   Reply With Quote
Old 05-23-2018, 08:32 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Door and front clip compatibility.
Doors are not compatible except the door skin could be reworked. Nothing else on the door will interchange except the door handles inside and out.
Old 05-23-2018, 08:33 PM   #3
aerotruk63
aerotruk63's Avatar
Front clip would be the same except for the emblem holes.
Old 05-23-2018, 08:42 PM   #4
darby555
Thanks for the info! Are the 63 and 66 chassis' the same? Would the cab and entire sheet metal bolt on to a 63 frame?
Old 05-23-2018, 08:49 PM   #5
darby555
Old 05-23-2018, 11:44 PM   #6
Captainfab
60-66 Nut
The '63-'66 frames are the same except for the panhard bar bracket on the frame.
