Old 05-28-2018, 01:26 AM   #1
jbice70gmc
jbice70gmc's Avatar
CPP bent panhard bar
I just put a new CPP (bent version) panhard bar on the truck but it looks like the panhard bar is a little long. It sticks out 1/2" on the passenger side. I need to callapse the panhard bar about 1/4" to get it even. The bar is collapsed as far as possible with the locking nut in place. If I remove the locking nut I should be able to get the 1/4" I need. I think this should be fine as this is a single adjustable panhard bar. Once it's in place there is no way the length of the bar will change. Just wanted to hear any issues you guy's think removing the locking nut may cause. Thanks
1969 GMC SWB Fleetside
http://67-72chevytrucks.com/vboard/s...d.php?t=486320
jbice70gmc is offline   Reply With Quote
Old 05-28-2018, 09:10 AM   #2
Tiger Joe
Re: CPP bent panhard bar
I’m pretty sure I had the same issue with mine and removed the nut for the extra
And yes there is no way it can spin once installed.
Tiger Joe is offline   Reply With Quote
Old 05-28-2018, 12:07 PM   #3
RodnRudy
RodnRudy's Avatar
Take the bar off and cut 1/2" off the threaded end. That will give you enough room to put the jam nut on and tighten it down. You do have the rear end centered in the wheel wells correct? Check that first. You need that jam nut on the adjuster because of the play in the threads, and it needs to be tight.
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 05-28-2018, 09:54 PM   #4
jbice70gmc
jbice70gmc's Avatar
Should be easy enough. Do you know how much of the bar is threaded? I'm at work right now reason I'm asking. That will be easy to check as well.
Old 05-28-2018, 10:08 PM   #5
RodnRudy
RodnRudy's Avatar
No but if you threaded the adjuster in all the way you should have enough thread depth after trimming. If not just cut some off the adjuster.
Phil
Old 05-28-2018, 10:10 PM   #6
jbice70gmc
jbice70gmc's Avatar
Gotcha. Thanks
Old 06-03-2018, 04:34 PM   #7
Redneck Rydes
Redneck Rydes's Avatar
I used the Western Chassis adjustable bar.I has adjustment on both ends.just bolt in and turn bar to tighten,no straps needed.
Redneck Rydes is offline   Reply With Quote
Old 06-03-2018, 04:36 PM   #8
jbice70gmc
jbice70gmc's Avatar
I had to get the CPP bent bar because of my Moser rear diff cover. They are single adjustable.
