axle painting primer or no primer
painting my rear axle today hopefully, just likely some rattlecan Tremclad or some other Rust paint. should i use a primer first though?
or do i go whole hog and POR-15 it? |
![]() Join Date: Oct 2011
Re: axle painting primer or no primer
Think the answer would very on how much prep work you put into the axle.
If you have spent many hours cleaning it down to the bare metal and have it spotless, than ya, spray come primer on it. If you hit it with a water hose and still have bits of gear gravy on the outside, than just use some rattle can. |
#3 | |
![]() ![]() Join Date: May 2015
I just got thru painting mine....I cleaned and scrubbed with scotchbrite pad and wire brush with mineral spirits and purple power. ...it cleaned up pretty good but not sandblasted clean...when dry I then sprayed it with krylon colormaster paint+primer in matte black. .(says dtm on can)..looks decent but not show quality....I've used this method before with good enough results...
I would finish it off with a wire brush and clean it like Mongocanfly and hit it with a nice paint primer combo. |
I'm working on a transfer case now. ....it has lots of (gravy) on it...what a pain....
ill prime the transfer case before I paint it...the paint I'm gonna use on it is not a dtm style paint. .....
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 05-30-2018 at 07:30 PM. |
Every paint on the market is made better by applying a primer.
So when is this "Old enough to know better" supposed to kick in? My 1959 GMC build thread http://67-72chevytrucks.com/vboard/s...d.php?t=686989 |
Depends what you want it to look like few years down the road. My best results are tremclad top coat over por15. Tremclad only i have rust forming just sitting in the garage after a few years. My trans and trans case has por15 then tremclad over and they are just as clean as when i painted them.
BRIAN 1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater. My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509 ![]() |
imo... rattle can paint is only better than no paint, but not by much
better off with brushing on rustoleum or por15
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
