06-05-2018, 09:32 PM | #1 |
Dakota Digital HDX with the OBDII BIM module
Anybody else running these components with their LS swap? The HDX gauges with the bim module (pulling all data from the OBDII)......
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
06-06-2018, 09:03 AM | #2 |
Re: Dakota Digital HDX with the OBDII BIM module
No, but they sound interesting if they're CAN based, as then they might work with things like the Holley injection as well, since it supplies a CAN bus signal.
They just snoop on the CAN wire pair and report standard PIDs like oil pressure and O2 and so on?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
06-06-2018, 09:10 AM | #3 |
I have and they work great. The only problem that I have run into is that if you need to plug in your scanner, you have to unplug the gauges.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-06-2018, 10:18 AM | #4 |
BMW & ASE Master Certified
Yepp, can't use up tuners and gauges... took a while to figure out that one. But simply using a plug for the gauges instead of hard wiring solved the issue.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
06-06-2018, 01:00 PM | #5 | |
I got my first HDX gauge set and it had a bad button - wouldn't go into setup mode. Sent it back to DD. They either fixed it or sent me another one. The note said "no problem found" but it works now so whatever. During initial setup of this second one, through my ipad on bluetooth, it does not recognize the pcm. The BIM module diagnostics (lights and those codes it can flash) says that IT is communicating with the PCM fine and dandy but the cluster says it doesn't see it. Everything is hooked up the way it is supposed to be. I am hoping (REALLY hoping) that the cluster did not see the PCM because the engine wasn't running. That doesn't make a lot of sense to me but I'm running on hope right now. I can't start the engine to confirm this until I get a few more things plumbed up. PCM is good- its got hours of testing and runs the engine fine. I just hope I don't have another cluster issue. I had to pay over $40 in shipping/insurance to send the first one back to DD which pissed me right off since it was bad from the start. If I have to send it back again I will not be a happy camper. Any thoughts?
06-06-2018, 01:22 PM | #6 | |
06-06-2018, 01:34 PM | #7 | |
I can get gauge readings for voltage and fuel level, but of course, both of those are independent of the PCM. I don't see anything else, but with the engine not running, they would be all at zero anyway. If I have to take this dash apart a third time.......
06-06-2018, 01:37 PM | #8 | |
06-06-2018, 08:05 PM | #9 |
Im running VHX with the module and for this reason above I thought about atleast running the VSS and tach direct to the engine harness so as not to lose them while tuning or troubleshooting.
06-07-2018, 09:04 AM | #10 | |
I guess its a network issue with the CANBUS communications. I had a similar issue here installing some new software to allow in-house programming of our commercial/pro motorola 2-way radios. The computer was getting confused as it recognized the radio as an additional network that was causing conflict with the LAN network (interwebs). Nothing worked until we unplugged the LAN. Took a while to figure that one out! I need to get my kids involved in this. I'm starting to feel like my Dad around this ever-changing tech.
06-11-2018, 09:20 AM | #11 | |
Have you ever tried one of these Dual OBD2 adapters? I have the HDX gauges for my truck and I was going to give this a try when I get to that point. https://www.amazon.com/iKKEGOL-Split...obd2+connector |
06-11-2018, 09:27 AM | #12 | |
03-26-2019, 11:40 PM | #13 |
I made my own and it doesn’t work. I had to unplug one to use the other. I just installed my hdx set up and just unplug when I have to tune the truck.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
03-27-2019, 10:53 PM | #14 |
04-09-2019, 02:44 PM | #15 |
Question about the BIM.
Have you connected a scanner to your OBD2 port to verify that it works OK? Also, you need to make sure the BIM is set to read the "J" protocol. It should work regardless if the engine is running or not as long as you turn the key on. Weare having problems with the BIM connected to the OBD the engine will start and run for a minute or two and then stalls. Unplug the BIM and all is good. Do you think the "J" code is the problem? Sorry for the hijack __________________
04-29-2019, 10:24 AM | #16 | |
disclaimer, i expect it back tomorrow or wednsday to verify the fix. problem was truck ran perfect, plugging in the bim caused it to stumble randomly at idle and try to die flashing the check eng lite. un plug bim runs perfect. |
05-01-2019, 10:29 PM | #17 | |
I just found out i have the same problem with my suburban stalling.
Nice expensive fix for me. Just send it bavk to us...great if only I was in the US wouldn't be a problem. Quote:
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
04-29-2019, 10:43 PM | #18 |
Following, as I will most likely be buying the hdx or vhx kit soon once I see who has a better deal on them
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's Project "Huckleberry" 68 GMC K1500 1/2 ton L83/6L80e |
04-30-2019, 08:01 PM | #19 |
Not quite the HDX, but I installed a VHX gauge system for my '86 with the Bim module late last summer. I have a PSI harness and PSI supplied E38 ECU/T42 TCU(4L80). I used an OBD splitter from Amazon. The gauge panel works great so far, knock on wood...
Hooking a scanner to it was interesting but worked. The code readers I have did not completely connect when I turned the key on initially. When I turned the key off it finally displayed codes and let me clear them. I think the scanner worked after turning the ignition back on at that point too. I've forgotten some details. I had a misunderstanding with PSI when I talked to them about using the BIM module. I have an L96 6.0 with VVT. The PSI harness has the stock oil pressure sensor plug and the Bim module uses it. A PSI staff member had originally told me I needed to add the dakota digital oil pressure sensor to the engine also, which I did at first, but it wasn't needed after talking to a different PSI staff member during a different phone call. |
12-29-2019, 11:40 PM | #20 |
Anybody know what is included with a 2003 ECM? Does it provide all of the following that the BIM can use?
VSS TACH OIL Pressure Water Temp Trans Temp Gear indicator Cruise Control light on dash Check Engine Light .
TA_C10 Stage 1 build - http://67-72chevytrucks.com/vboard/s....php?p=8333444 "It's only money". |
01-03-2020, 10:01 AM | #21 | |
VSS Water temp Trans temp gear indicator Tach should show up but i ran the white wire from the ecm to the bim check engine light i also ran the tan mil light from ecm to the bim i didnt have cruise so i dont know if the light shows up. oil pressure is not shown. i had to run the DD sender unit and wiring. also wiring in a 2nd aldl connector doesnt work. when the DD is plugged into 1 port it wont allow a scan tool (gm tech 2) or a tune tool (hp tuner or efi live) to communicate with the ecm. you HAVE to unplug the DD before trying to communicate with the ecm anyway. this is just my experience on a 411 warren pcm which i have done a few swaps with. |
01-03-2020, 10:44 AM | #22 | |
01-03-2020, 05:31 PM | #23 |
anyone have issues with their gauges cutting out? I have the BIM with VHX in my pickup. High RPM accel 'power' them down and they restart. Its only the gauges run through the BIM module that have seem to have this issue. Using the 0411 PCM as well. Just kinda frustrating cause i cannot see the rpm or speed when flooring it.
12-02-2020, 01:53 AM | #24 | |
12-02-2020, 11:41 AM | #25 |
EDIT: Nevermind - seems you got oil pressure, which is pretty awesome.
