Old 06-12-2018, 01:12 PM   #1
Tonner
Transmission line fittings
I have a '72 C20 with a TH350 transmission. I bought it in pieces, so I never saw the transmission cooler lines connected. Both ends of both lines have flared ends and fittings. One of the flare fittings on the transmission end is screwed into a separate brass adapter with the same size threads and a flat end. Of the four ends, it's the only one and there are none in the bolt bags I received with the truck. Is the adapter supposed to be there? Should both lines have one? Should both lines have two? What is the adapter called and where do I get more? I tried threading them all in as-is, but the non-adapter line leaks from the transmission end. All appeared to tighten just fine.
Tonner is offline   Reply With Quote
Old 06-12-2018, 01:35 PM   #2
geezer#99
geezer#99's Avatar
Re: Transmission line fittings
Some info here on what you need.
http://www.v8s10.org/forum/viewtopic.php?f=19&t=37197
geezer#99 is online now   Reply With Quote
Old 06-13-2018, 12:32 AM   #3
67c10rustbuket
67c10rustbuket's Avatar
Each port on the transmission should have a brass adapter 1/4 NPSM X whatever inverted flare. Just go to your local dealer and buy one or two if you are missing them. Part number 8637742, I just bought two myself last week. Cost about $7 each from GM.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 06-13-2018, 01:11 AM   #4
chewychevy67
I too just had my transmission rebuilt but these were not on the tirbo 400 so I found some. Are they supposed to have a brass washer between them and the transmission aluminum body or will they seal up when without the washers?
chewychevy67 is offline   Reply With Quote
Old 06-14-2018, 01:41 AM   #5
Tonner
Man, none of the local parts houses had them. Napa said it was a special order item that would cost ten bucks plus UPS freight. O'Reilly's said they couldn't get it even though I read them the part number off their own website. I finally contacted the local hydraulics supply store and the carried them.
Old 06-14-2018, 07:47 AM   #6
ga-stepside
ga-stepside's Avatar
Type gm 8637742 into EBay search.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 06-14-2018, 09:32 AM   #7
67c10rustbuket
You can buy these at any GM dealership parts department. If they’re not in stock they can get them next day. If you don’t have a GM dealer close I think Jegs and summit sell them too.
Dan <---(my name)
