A little support for my 72 driveshaft support bearing
I have seen where these carrier bearing mounts break off on this style so I added a little support. This is a fernco rubber pipe hub I got at lowes. I cut it at 6 1/2 inches, I should have done 7 1/2. I think I will get another one. The ridges on the side hold it in nice and tight. I sprayed it with WD40 and tapped it in from the transmission side.
http://67-72chevytrucks.com/vboard/s...d.php?t=698292 |
Re: A little support for my 72 driveshaft support bearing
Nifty! Let us know if you can feel and additional vibrations or sounds and how it turns out in time. Looks like a great idea to me.
Not sure that will prevent the metal from breaking however I think having one in the tool box might get you home if the bearing housing does break.
I recently replaced my hanger bearing, not due to the metal breaking, the rubber was worn out and shaft was scraping on the housing. Bill
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
![]() Join Date: Feb 2010
Location: Falls City, Nebraska "100 Miles From Nowhere"
I like it, I like it a lot...I'm wondering if a full radiused piece with a single slit to clear the stem at the top? Zip-tie and it should help dampen and keep the bearing stem located and held in position..?
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" ![]() "Be American, Buy American" ![]() |
I tried to get more of it in there but couldn't get it to go. I am sure I can get the 7 1/2 inch in which should go half way around. I think it will be plenty.
![]() Join Date: Nov 2006
Waste of time
I BELIEVE IN JOHN 3:16 |
In your opinion? How can dampening a vibration be a waste of time? Not trying to start a pissing contest but please explain how or why?
It wont stay in.......... And its not 100 percent contact.
