Old 06-24-2018, 06:51 PM   #1
Lanman1972
Lanman1972's Avatar
Am I missing a bushing
Where the automatic trans linkage connects to the steering column, mine is sloppy should there be a bushing at this connection? Thanks guys!
1972 C10 Custom Deluxe LWB, 402/400, PS, PB, A/C, Highlander, Hugger / White
1971 C10 Cheyenne LWB (SWB), 350/350, PS, PB, A/C, Dark Olive / White.
Lanman1972 is offline   Reply With Quote
Old 06-24-2018, 06:56 PM   #2
bill3rail
bill3rail's Avatar
Re: Am I missing a bushing
Not sure about bushings, but look at the rod to see if it is worn the hell out. It is usually fairly obvious when a rod or hole is worn out.
1970 C10 8' Fleetside, L6 250, 3 on the Tree.
The most basic of pickup trucks!
bill3rail is offline   Reply With Quote
Old 06-24-2018, 08:06 PM   #3
68C15
blood type; Retumbo
68C15's Avatar
Should be a plastic bushing in there. I'm not sure but I think the same bushing was used up into square body years, maybe even further
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 06-24-2018, 10:58 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
There are quite a few pieces that go in there. Using the picture at bottom left, starting at the bottom: adjustment bolt/clamp (on the rod), Adjustment bolt cupped washer, metal or plastic sleeve, rubber grommet, shifter arm, washer, lock washer, & nut.
The rubber grommet fits inside the shifter arm and the metal or plastic sleeve fits inside the rubber grommet.
LockDoc
Leon
Old 06-25-2018, 10:24 AM   #5
Lanman1972
Lanman1972's Avatar
Thank you everyone. Looks like I need to make a bushing.
