72 brake booster
Can I use my original booster brackets that bolt to fire wall on a after marker dual diaphragm booster?????????
OLDIRONRACING |
Junior Member
![]() Join Date: Jul 2014
Re: 72 brake booster
Don't see why not. If the booster is designed for the truck then the bolt pattern for both the bracket and the master cylinder should be the same. On the back of the boosters you should probably check the position of the pistons. You may need to adjust the pivot arm slightly if they're different.
Scrapper 1
all of the 1968--72 have 4 bolt hols on the fire wall the 1967 not sure But Its like new trucks that have options but it did not come with.The wiring is not there But the holes are there for the upgrade.GM was wonderful about that make one that fits all options
Collector of Projects
Use a CaptainFab bracket to clean up the firewall but you also need to swap to a lokar cable operated column shifter unless you have a floor shifter. Mounting the booster closer to the firewall causes interference with the factory column shifter.
http://www.67-72chevytrucks.com/vboa...d.php?t=347484 ![]() |
