Old 07-03-2018, 09:56 AM   #1
thedudeabides86
Active Member
thedudeabides86's Avatar
Could anyone spring into action post and cut me a brake? See what I did there?
Soooooo, working on this ol mess. I've got all the parts off and installed the new wheel cylinder. I cleaned up the back plate. The old wheel cylinder leaked and prevented me from bleeding the brakes efficiently since the pedal just dropped down to the floor. I got all my parts at O'Reilly down the street and for replacement spring kits they offer an 11" or 11.5". How do I know what spring kit to use? I can't find anything anywhere that helps to determine what size kit I need. Anyone help me out? I'd really appreciate it.
The Dude abides.
thedudeabides86 is offline   Reply With Quote
Old 07-03-2018, 10:09 AM   #2
Rickysnickers
Re: Could anyone spring into action post and cut me a brake? See what I did there?
You could try measuring the inside diameter of the drum. That should tell you. If you got replacement shoes, did you buy the 11" or 11.5"? That's another way of knowing, and I'm not intending to crack wise with that question.
Old 07-03-2018, 10:45 AM   #3
thedudeabides86
Active Member
The replacement shoes measured at 2.5" wide, but when you refer to them as 11" or 11.5", do you mean the overall length of the shoe itself? I believe the inside diameter of the drum measured about 12". I can get more info once I get outta this slow and boring work day. Bah!
The Dude abides.
Old 07-03-2018, 11:16 AM   #4
RustyBucket
RustyBucket's Avatar
Tell the boss you're sick & go home. Wash up the old hardware and compare it to the parts in the two kits. Return the kit you don't need & swap it for a kit for the other side. I highly recommend retirement as an option.
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 07-03-2018, 11:40 AM   #5
B. W.
B. W.'s Avatar
11" or 11.5" refers to the diameter of the drum. (don't think these trucks came with 11.5) If your rear end is a Dana 60 & you have 12" drums then you may have a hard time finding the correct kit. 12" drums were used one year only. (1971)
B. W. is offline   Reply With Quote
Old 07-03-2018, 11:52 AM   #6
kwmech
That is not true, all the Dana 60s had 12'' drums. I've had 3 different trucks both 2wd and 4wd with D60s all were 12''. I currently have a 68 GMC--2wd, 3/4 ton Dana 60...12'' drums.
Old 07-03-2018, 01:35 PM   #7
thedudeabides86
Active Member
I guess I'd better figure out what type of rear end I've got. Is there a specific way of knowing? This is a 3/4 ton C20.
The Dude abides.
Old 07-03-2018, 04:49 PM   #8
toolboxchev
Roger that one. I have a 70 c20 with a dana 60 with 12 x 2.5 brakes.
toolboxchev is offline   Reply With Quote
Old 07-03-2018, 01:23 PM   #9
thedudeabides86
Active Member
Ha! I've been trying to retire since I discovered that work sucks. I've still got the old springs so I should be able to match things up. The guy at O' Reilly mentioned I could return the kit I didn't use even if I opened it. I figure I'll open it nicely so the next guy that buys it doesn't get screwed.
The Dude abides.
Old 07-03-2018, 11:45 AM   #10
demian5
demian5's Avatar
Measure the drum diameter and width and go to rockauto to get part numbers.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 07-03-2018, 04:42 PM   #11
demian5
demian5's Avatar
Man, we can sometimes beat the crap out of a subject so bad. Starts with someone asking about a carb, ends with a new right rear cab mount.
CLICK HERE:
https://www.rockauto.com/en/catalog/...dware+kit,1752
1986 C20 Scottsdale
Instagram: C10sofOC
Old 07-03-2018, 08:21 PM   #12
Mike_The_Grad
Mike_The_Grad's Avatar
Judging on everyone's input, it seems as though 5-lug would be 11", 8-lug would be 12", so through process of elimination 11 1/2" should be 6-lug. But I'm just shootin in the dark.
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline   Reply With Quote
Old 07-03-2018, 11:13 PM   #13
dmjlambert
dmjlambert's Avatar
I was looking through the LMC catalog for some parts for my brakes and saw this
Old 07-03-2018, 11:20 PM   #14
Steeveedee
Who Changed This?
Steeveedee's Avatar
OK, I'm not Mr Truck, but I will say that I have never seen or heard of 11-5/32" brake drums.
~Steven
Simi Valley, CA
Old 07-03-2018, 11:25 PM   #15
dmjlambert
dmjlambert's Avatar
Apparently O'Reilly just calls them 11 and a half, but LMC knows they are 11-5/32. They must have gotten out a measuring stick...
Old 07-04-2018, 07:42 AM   #16
aerotest
11-5/32 brakes are the heavy duty option for c10s. They came on suburban. They use 3/4 ton wheel cylinders. Took me many trips to the part store to figure that out.
1969 C10 Suburban Custom (Factory 396/TH400, survivor with no rust)
aerotest is offline   Reply With Quote
Old 07-04-2018, 11:39 AM   #17
Steeveedee
Who Changed This?
Steeveedee's Avatar
I've done hundreds of brake jobs, but never on a Suburban. I learned something today!
~Steven
Simi Valley, CA
Old 07-05-2018, 11:19 AM   #18
thedudeabides86
Active Member
So, update on the brake job. I tried taking off the driver side brake drum and I believe the shoes are tightened up against the drum. I've got the spoon adjuster and tried to back the shoes off, but I can't turn the star adjuster wheel back. I watched a YouTube video where a guy pushed a lock up and away and then was able to back it off. That was with the drum off. Any suggestions on getting at the lock and backing the star adjuster back besides going insane attempting it? Ughhhh. It's very frustrating This is my first time doing brakes on this thing. Nothing like being a rookie and trying to get things to work out..... Thanks for all the advice so far on this thread. I really appreciate.
The Dude abides.
Old 07-05-2018, 11:34 AM   #19
B. W.
B. W.'s Avatar
I use a small rod to reach in through the hole on the backing plate. Push on the adjuster lever while turning the adjuster with your spoon.
Old 07-05-2018, 11:39 AM   #20
thedudeabides86
Active Member
The adjuster lever is what's locking the adjuster into place? I can look at a diagram and see where the adjuster lever is in hopes to disengage it from the wheel to back the shoes off.
The Dude abides.
Old 07-06-2018, 08:37 AM   #21
ryans69chevy
Just a thought... does your drum still have rivets where the wheel studs are poking through? Something like 3 rivers? If so you have to take the dust cap off and take off the nut that holds the hub to the spindle.
ryans69chevy is offline   Reply With Quote
Old 07-06-2018, 02:34 PM   #22
ncpetersc
ncpetersc's Avatar
In case the post got overlooked, did you check this?
http://67-72chevytrucks.com/vboard/s...d.php?t=384059
Last edited by ncpetersc; 07-06-2018 at 02:37 PM. Reason: Found another thread referring to these rivets.
ncpetersc is offline   Reply With Quote
Old 07-06-2018, 10:47 AM   #23
dmjlambert
dmjlambert's Avatar
The next thing I would try is cutting the nail heads off or grind them off with a dremel tool, from the back side. That way the whole thing would kind of fall apart when you pull the drum.
Old 07-06-2018, 10:56 AM   #24
kwmech
Last rusted axle I worked on met its fate with a cutting torch and got all brand new parts. I literally had to cut the drum in half.
Old 07-06-2018, 11:55 AM   #25
thedudeabides86
Active Member
The pins or nails from the keeper springs fell out the back of the dust plate, that's how I know the whole assembly is loose. I can't figure out why I can't just pull the whole drum off with all the guts of the brake assembly in tact. Perhaps it's on crooked. If I straitened out the drum and pulled it all off straight, perhaps? GAH!
The Dude abides.
