07-09-2018, 03:41 PM | #1 |
In-bed Spare tire mount on ‘84 k5
Hello all. I’m hoping someone could post a couple of pics, actual or diagram, of the mounting of the spare tire carrier with tire attached. Two most curious points:
1. How does upper arm attach. It appears as though the upper arm mounts to the rails area but right at a bolt hole that would hold the top. Not sure how that works And 2. I’m missing the plate/bolt that would fit over inner wheel. So what do I need or what could I use in place of if I’m unable to locate that hardware. Thanks so much. I’m looking forward to getting this mounted if only for the look of it. Pretty badass looking indeed. Last edited by Newtynewt; 07-09-2018 at 03:46 PM. |
07-10-2018, 12:42 AM | #2 |
Re: In-bed Spare tire mount on ‘84 k5
The upper arm should swing around. So it just goes over one of the top holes and it bolts down then the other parts bolt to the floor. I have one in the back of my pick up truck I swiped do it if a k5 I used to own. you can pretty much use anything to hold the tire to it
07-10-2018, 07:56 AM | #3 |
Thanks so much for the reply.
Posted via Mobile Device |
