![]() Join Date: Dec 2012
D99 paint divider trim
Hey guys,
I want to put the D99 paint divider trim on my truck that is below the rear window. I have seen a few threads on it but cant find how to attach the little studs that hold the clips on to hold the trim. I have a parts cab with the stud on it for locations but not sure what to use or how to attached them to the my cab that did have them from the factory. Any help would be great. Thanks Scott
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO ![]() |
Re: D99 paint divider trim
Two options:
1. weld on studs using a body stud welder with a special attachment 2. screw on studs |
#3 | |
Or even the screw in studs? Could you even pop rivet them on?
![]() Join Date: Aug 2004
Most body shops have the stud welder and could do it for you. If you mark out where the studs go it would be a quick job and probably not cost much.
There are the screw in type, but that's a lot of holes to worry about rusting.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
![]() Join Date: Dec 2013
If the truck is already painted use the screw in type or pop rivits if it hasn't already been painted you could use the weld on studs .It's not cheap to have them installed .
#6 | |
Thank you
I am not familiar with the trim clips. Are they this type of stud?
![]() If so they were used on a lot of GM trim especially front and rear glass trim.
Moderator
![]() Join Date: May 2007
Yes
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
So where would one get these screw in studs and the molding?
There's something women like about a pick-up man 1967 c10 swb Stepside 2004 SSR 2013 Silverado swb |
![]() Join Date: May 2010
Classic Industries sells them. I assume other suppliers do as well. Maybe even your local Chevy dealer.
Here's the Classic Industries link. https://www.classicindustries.com/sh...rts/?q=4492963 |
![]() Join Date: Mar 2000
Any Autobody supplier will have them. a Unispotter stud gun comes with the studs and the tip to put them on. These are a common thing. And they will never leak.
Saskatoon, Saskatchewan Canada |
Wow. Ok guys Thank you for all the suggestions
I think I would go with the river idea instead of screws. But want to weld them if possible. I will stop by my local body shop as see if I can buy a dozen or so. Thanks again. I will post a picture of what I do. Before and after!
H&S or unispotter # 1003 is what looks like I need. But I don’t need 500 of them. And the adapter is about $30 Anyone have the adapter I can borrow and a dozen or so of these rivets?
#15 |
To use a stud gun you need an 1 1/4" of bare metal around each stud you intend to apply ,They have to be perfectly straight and then you have to deal with doing body work around each stud which is a PITA , if you don't get good adhesion when spotting them on they can come off usually when your finished with paint and installing the trim. It's much easier to align your trim /drill your holes and then finish all your paint work , Slide the plastic molding clip onto the rivit stud and THEN rivit them to your truck . if you worried about rust use some flow grade sealant on each one prior to installing .
![]() The problem with the screw in studs is they are a #1 phillips head screw diver and if your driver doesn't fit really good to the screw they can easily slip leading to paint gouges and scratching This is why the rivits are easiest /faster and less expensive .I have 2- 67 cabs I'll be fitting trim to this next week if you need pictures , Last edited by Grumpy old man; 07-19-2018 at 06:11 PM. |
#16 |
[QUOTE.I have 2- 67 cabs I'll be fitting trim to this next week if you need pictures ,[/QUOTE]
I am in for pics.
#17 | |
GOM. Everything I have read is pretty much Word for Word what you have wrote on this post regarding these types of trim secure points . I agree with you about the rivets but I want to weigh all the options. I don’t like the screws and if I can weld them on with certainty that they will remain that’s the best option. But definitely faster with the rivets. I think I am going to order the rivets and test it out on some sheet metal. Thank you
Also I am down with pictures of you for kind. I will post a link to the weld on drugs and the adapter just in case someone at a later date reads this. Thank you guys! Quote:
#18 |
Grumpy any updates on trim mounting?
I ordered set a rivets hopefully they’re in this week I’m ready for paint!!!
#19 |
#20 |
Hey guys.
I got the trim out and got it marked up on the cab. I was able to get the info off the parts truck. The ziplock bag was $32 for 20 rivets. Crazy right? The rest are pictures of the studs riveted on. It was easy after the locations were found. I did add a little seam sealer to the rivet before I crimped them in.
#21 |
it looks like you got it ! You may want to cover the studs before paint so the clips which fit tightly will slide on easier ,Leave the tubing about 1/16 off the body of the truck so it just covers the stud but allows paint at the base .
![]() http://www.beldenspeed.com/beldenspe...epop-rivettype |
#22 | |
All about them K’s
![]() Join Date: Jun 2014
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
#23 |
Subscribing also....I like those pop-rivet studs better than the screws.
#24 |
![]() Join Date: Jun 2019
I'd like to add this trim to my cab also. It looks like it centers on the bottom edge of the drip rail??
#25 |
![]() Join Date: Feb 2019
where are the Pop Rivet studs available?
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
