Old 07-21-2018, 04:04 PM   #1
Perpendicular
67 Ignition Switch and Ash Tray oon 68 - newer dash
I understand the bezel is bigger on the newer dashes, but what piece goes on the switch to hold it on the backside of the dash? Anyone have any pictures? I see I can buy a new bezel but I cannot find anything for the backside :/
Also, what about the ash tray? My 67 dash I am removing does not look the same as the new dash I have now. Do I need to get a complete new setup?
-Paul
Perpendicular is offline   Reply With Quote
Old 07-21-2018, 04:24 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 67 Ignition Switch and Ash Tray oon 68 - newer dash
the 67 parts are 1 year only if your using a 68 dash you need 68 parts .
Old 07-22-2018, 08:28 AM   #3
Perpendicular
Thanks Grumpy. But what is the piece that goes between the ignition switch and the dash? The switch itself is interchangeable, but the back piece seems to be different and I can't find a reference to it.
-Paul
Old 07-22-2018, 10:31 AM   #4
Grumpy old man
Here you go , The lighter is different also
http://www.manestruckparts.com/store...&Category_ID=8
Old 07-22-2018, 07:41 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
That is called an ignition switch spacer. If you have a '67 with the small screw on bezel here is the spacer you need.
http://67-72chevytrucks.com/vboard/s...d.php?t=747570
If you have a '68-'72 with the large screw on bezel any parts vendor will have that spacer.
LockDoc
Leon
